need schematic for DELL P69G001 board SL KBL-R A00 17810-1 28JF7 or identify IC
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    or help me identify IC that can cause problem
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: need schematic for DELL P69G001 board SL KBL-R A00 17810-1 28JF7 or identify IC
    looks like the ic is NCP81382
      • 21850
      Schematic
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        Originally posted by SMDFlea
        Schematic
        Thanks mate
        where did u get all this schematic?
        do u have account in vinafix?
          • 21850
          Originally posted by ktmmotocross
          Thanks mate
          No don`t use vina. I have an account somewhere else but most of the schematics come from free sites.
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3627
            • slovakia
            But this is not schema for my board. ic that giving me trouble is PU4801 and it is not in this schema
            • piernov
              • Jan 2016
              • 4439
              • France
              Page 48
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3627
                • slovakia
                what a stupid marking on that schema
                  • 21850
                  D o`nt k now w hat y ou m ean
                  • Magnusa2
                    • Jul 2017
                    • 66
                    • India
                    its not the same schematic, i need sl kbl -r A00 17810-1 28JF7 SCHEMATIC
                    • naseee
                      • Nov 2016
                      • 104
                      • india
                      here schematic & boardview
                      • kuraimangetsu
                        • Nov 2022
                        • 78
                        • iraq
                        love you man!!
                        • osman68i
                          • May 2015
                          • 351
                          • The Netherlands
                          thank you
                          • jota_w
                            • Mar 2019
                            • El Salvador
                            The scheme is not complete
                            • Bowline
                              by Bowline
                              06-11-2025, 10:13 AM
                            • abajor
                              DELL XPS 9730 G3JX0$UA trying to identify chip that is getting hot.
                              by abajor
                              Hi all, I've been trying to find some information about this 2024 DELL XPS 9730 Have found absolutely no board views or schematics anywhere.
                              The laptop suffered some minor water damage around a power mosfet which I cleaned up and replaced. From what I can tell that p channel power mosfet source receives a 12V rail when a power supply is connected but its not passing voltage through the drain.
                              When I plug in the USB C charger with battery removed I'm drawing .2A at 20V
                              With battery connected it stays at 5V
                              Under a thermal camera I can see that this component...
                              12-14-2024, 10:36 PM
                            • Akhlz001
                              by Akhlz001
                              09-20-2025, 07:15 PM
                            • master3112
                              by master3112
                              07-29-2025, 01:55 PM
                              Dell Thunderbolt Firmware
                              by SMDFlea
                              Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                              Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                              The SKU is in brackets (****)
                              EDIT: NVM65...
                              01-26-2025, 06:22 AM
