need schematic for DELL P69G001 board SL KBL-R A00 17810-1 28JF7 or identify IC
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3608
    • slovakia
    or help me identify IC that can cause problem
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3608
    • slovakia
    Re: need schematic for DELL P69G001 board SL KBL-R A00 17810-1 28JF7 or identify IC
    looks like the ic is NCP81382
      • 21149
      Schematic
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3608
        • slovakia
        Originally posted by SMDFlea
        Schematic
        Thanks mate
        where did u get all this schematic?
        do u have account in vinafix?
          • 21149
          Originally posted by ktmmotocross
          Thanks mate
          No don`t use vina. I have an account somewhere else but most of the schematics come from free sites.
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3608
            • slovakia
            But this is not schema for my board. ic that giving me trouble is PU4801 and it is not in this schema
            • piernov
              • Jan 2016
              • 4437
              • France
              Page 48
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3608
                • slovakia
                what a stupid marking on that schema
                  • 21149
                  D o`nt k now w hat y ou m ean
                  • Magnusa2
                    • Jul 2017
                    • 66
                    • India
                    its not the same schematic, i need sl kbl -r A00 17810-1 28JF7 SCHEMATIC
                    • naseee
                      • Nov 2016
                      • 100
                      • india
                      here schematic & boardview
                      • kuraimangetsu
                        • Nov 2022
                        • 77
                        • iraq
                        love you man!!
                        • osman68i
                          • May 2015
                          • 339
                          • The Netherlands
                          thank you
                          • jota_w
                            • Mar 2019
                            • El Salvador
                            The scheme is not complete
                            • Bowline
                              by Bowline
                              06-11-2025, 10:13 AM
                            • abajor
                              DELL XPS 9730 G3JX0$UA trying to identify chip that is getting hot.
                              by abajor
                              Hi all, I've been trying to find some information about this 2024 DELL XPS 9730 Have found absolutely no board views or schematics anywhere.
                              The laptop suffered some minor water damage around a power mosfet which I cleaned up and replaced. From what I can tell that p channel power mosfet source receives a 12V rail when a power supply is connected but its not passing voltage through the drain.
                              When I plug in the USB C charger with battery removed I'm drawing .2A at 20V
                              With battery connected it stays at 5V
                              Under a thermal camera I can see that this component...
                              12-14-2024, 10:36 PM
                            • master3112
                              by master3112
                              07-29-2025, 01:55 PM
                            • F R 2568
                              Dell Latitude 5420 does not start (no post) need help to find the reason why
                              by F R 2568
                              Hello all,
                              this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                              I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                              If the laptop is only connected to the AC adapter (battery removed):
                              When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                              The power/battery...
                              01-08-2025, 05:45 AM
                            • diamon
                              Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                              by diamon
                              I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                              Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                              Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                              Pictures of these boards:
                              Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                              Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                              Dell...
                              02-28-2024, 12:51 PM
