boardview for iPhone 7
  • Deluccia
    • Aug 2017
    • 46
    • uk
    Hi, Im sorry I can't seem to be able to find how to post new questions here.
    I was wondering if anyone knew a component name to search as i cannot find a boardview for iPhone 7.
    I have one here that has had a bodge repair to the board and as a result there is a damaged area between the two screen connectors.
    At the very bottom of the board between the screen connectors there is a small 5 pin square chip and next to it a 375 capacitor. I have found that the chip is damaged and the capacitor is missing so i am trying to find a replacement chip without buying a donor board.
    CAN ANYONE PLEASE HELP?
    Picture attached shows where the chip and cap were located, i had to remove them to fit a jumper wire.
    Thanks so much!
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Any digital electronics experts? Need help with iPhone 6s
    Thanks so much!
    iphone 7 board view
    • Deluccia
      • Aug 2017
      • 46
      • uk
      Thankyou very much.
      Can you please explain how i use this?
      Currently I use .BRD files for MacBook and view them on openboardview.
      What software do i need for this .rar file or does it need to be converted?
      - Joey
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        Thankyou very much.
        - Joey
        sorry i thought this was the iphone 7 board view ive just unzipped it and its a pdf of the schematics for one i dont have a actual board view sorry
        • gabiz_ro
          • Mar 2011
          • 167
          Check this
          https://www.4shared.com/get/SJITYCHs...schematic.html
          • Deluccia
            • Aug 2017
            • 46
            • uk
            Yes thank you but how do I open it to view it?
            • gabiz_ro
              • Mar 2011
              • 167
              iPhone 7 full schematic.rar you need winrar or any other compatible archive extractor.
              iPhone 7 full schematic.pdf you need acrobat reader or any other pdf reader.
              • Deluccia
                • Aug 2017
                • 46
                • uk
                Is that the same with MacBook?
                so I use this winrar to extract the file then what am i left with and how do i view it?
                open boardview?
                Pads?
                testlink?
                Sorry for all the questions.
                Is there not a .BRD iPhone 7 file? I can open them right up in open-boardview
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  There are no .BRD files for iPhones. They are all .pcb files which need Mentor Graphics PADS viewer to view them.
                  • Deluccia
                    • Aug 2017
                    • 46
                    • uk
                    I can't get winrar to work or anything this is a nightmare
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      Does it appear to have an OS-rebooting issue, or does it appear to just turn off then back on? (like a bad DC-in solder joint)
                      I had a reboot loop issue with my Samsung Galaxy S5 in 2016, IIRC, and it was Android in a corrupted state. Have you tried to repair iOS?
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      Arc A770 16 GB
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        if anyone has a full vinafix account there is a pads .pcb file in this thread post 3
                        https://***********/threads/iphone7-...ardview.26507/
                        • Deluccia
                          • Aug 2017
                          • 46
                          • uk
                          I can't access any of this why is it so hard!!
                          • acedogblast
                            by acedogblast
                            11-02-2024, 05:13 PM
                          • Paulo11
                            Iphone 12 mini boardview component codes
                            by Paulo11
                            Have somebody please iphone 12 mini boardview with component codes that are same like in schemas ? I need at least a picture of caps around nand. Or is there a way of "pairing" a component code from boardview with schemas ? I have boardview file from that large XZZ dump what can you find in this forum.
                            02-20-2025, 04:37 PM
                          • corrize
                            Desoldering - soldering BGA chip close plastic mini fpc connectors ?
                            by corrize
                            Hello, I need your advise please ? I need to remove and replace the BGA black chip with fpc connectors around. The PCB is small, from camera.
                            There is no plastic component directly under, on the other face, (only fuse and oscillator I can remove if they are sensitives to heat), but there is a lot of very small smd components I don't want to desolder by mistake.
                            I have :
                            - hot air, and a
                            ll stuff around
                            - true kapton tape
                            - 140 and 180 degree soldering paste
                            - bismuth
                            - little hot plate 250 degree max
                            - the new BGA chip with probably
                            05-20-2025, 01:26 AM
                          • Troystain
                            Help EZP2023+ updated chip database for w25q256jveq?
                            by Troystain
                            Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                            I need to add w25q256jveq chip but I do not know what data should I type.
                            I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                            The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                            11-25-2024, 12:53 AM
                          • ee91137
                            Mac mini M4 (A3238) Ripped Chip - Schematics+BoardView Needed
                            by ee91137
                            I'm looking for assistance with a Mac mini (M4, 2024), model A3238 (Model MCYT4LL/A), which I recently purchased. The front USB-C ports are not providing power.
                            Upon inspection, I've identified that a chip and an adjacent capacitor have been physically ripped off the logic board near the SSD connector.
                            Could anyone provide information on the specifications of this missing chip? Additionally, I would greatly appreciate it if anyone has access to the schematics and board view for the Mac mini A3238 logic board.
                            Thanks for your help!
                            07-13-2025, 11:00 AM
