hi need schematique and brd for macbook pro A1706 820-00094-A
  • the new
    • Jul 2020
    • 14
    • France
    hi i searched in internet and not finded it so i posted this reaquest
    thanks for help
    i need it to unlock efi password with ds-809s , thanks
  • the new
    • Jul 2020
    • 14
    • France
    Re: hi need schematique and brd for macbook pro A1706 820-00094-A
    no one have ?
    • piernov
      • Jan 2016
      • 4435
      • France
      820-00094 is not a MacBook main logic board model number.
      It's either 820-00239 or 820-00923.
      • the new
        • Jul 2020
        • 14
        • France
        ahh ok sorry this was writed on batterie
        i can't find motherbord model location
        • rilley
          • Jul 2024
          • 30
          • Romania
          Hello, sorry if it might be asked this question. I downloaded both 820-00239 or 820-00923​, how do I know for my macbook 13inch A1706, which schematic to use? Or I will find the part no. when I remove the motherboard off?
          Thank you in advance.
          • rilley
            • Jul 2024
            • 30
            • Romania
            Not sure how to edit my last post.
            I found it, I took out the board out and found the part no. is: 820-00923​-A < I think is related to the fact that my mac is from 2017 year, and there are also versions from 2016 year.
            Kind regards!
            • Danielreinaa
              HELP need password bios Macbook A1706
              by Danielreinaa
              Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
              Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
              Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
              gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
              Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
              09-07-2024, 03:47 PM
            • B2L_Repairs
              Macbook A1706 touchpad and keyboard not working. Please help
              by B2L_Repairs
              Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
              10-09-2023, 04:56 AM
            • obelix24
              A1706 - Macbook pro - one USB-C port only 20V 0A
              by obelix24
              I just got in my hands one Macbook pro A1706. It was originally not turning on (only 5V 0,2a on all ports (and 3 ports were restarting ampmeter when connected)
              I've replaced one CD3215C00 IC and now macbook is fully working (20V and charging fine)
              There is only 1 issue that one USB-C port is taking 20V but 0A (after replacing CD3215 it was fully working and i was charging macbook on this port) but then it just turns off (ampmeter) and started with only 20V 0A.
              There were some broken pads under CD3215 but i've recreated them.
              What should be...
              05-22-2024, 08:04 AM
            • johnbeton
              Macbook Pro A1706 820-00923 no power after replacing top cover and keyboard
              by johnbeton
              I have a A1706 with 820-00923-A board. The laptop came in with non-working keyboard. I bought a new top-cover with keyboard and transfered everything to the new topcover.
              Since then the macbook will not charge or power-up. Before replacing top cover, I started the macbook to test, and it worked fine apart from keyboard. Then shut it down and did replacement.
              This is what I measure so far:
              Resistance from F7000 to ground is 123 Ohm on pin 1 and 2
              PPBUS_G3H = 0,79v
              PPBUS_HS_CPU = 0,79v
              PPBUS_HS_OTH5V = 0,79v
              PPBUS_HS_OTH3V3...
              05-21-2024, 02:06 PM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
