vgsg mb rev:2.1 schematic
  • ravenmx
    • May 2018
    • 171
    • puebla
    please any have this schematic, the problem is the display leds no activation.
  • canali
    • Oct 2014
    • 192
    • turkey
    Re: vgsg mb rev:2.1 schematic
    toshıba l50-a model please any have this schematic, the problem is the display leds no activation.
    • balobi
      • Jan 2015
      • 88
      • phillippines
      Badly need schematics of this toshiba p50t-a
      boardcode: VGSG_GS MB REV 2.1 please... Thanks!
      • Albertoq
        • Jul 2019
        • 11
        • Perú
        Boardview VSGS-GS
        • Abdulkadertabbakh
          • Feb 2018
          • 10
          • syria
          thenks you
          • tojikatonoji
            • Sep 2017
            • 18
            • türkiye
            thanks
            • morenod
              • May 2022
              • england
              I downloaded the files, how do I read them?
              • Bartoloni
                • Jul 2018
                • 140
                • Italy
                you can use BOARDVIEW software
                .. BTW anyone have access to schematics of this board?
                i have 4 missing CAPS (i know that this maybe is not a big issue but seems that they are necessary for some sort of "filtering") ... the internal LED panel is not working (external with HDMI works fine)
                the missing caps are: C4540 C4539 C4535C4536
                i can't find any other missing component (and there are broken soldering pads only for these 4 caps looking with the microscope)
                they are probably removed by plastic back cover of the laptop during battery replacement
                (looking at theboard view these caps are connected to CPU and to DISPLAYCABLE)
                • Bartoloni
                  • Jul 2018
                  • 140
                  • Italy
                  well. just bought schematics... the caps are 100nF 25V
                  • alfredosn
                    • Jun 2016
                    • 19
                    • México
                    Hello Bartoloni, do you get the schematics? can you share it or can u tell me the value of the C8051 please, i need to replace it, but i dont know the exact value.
                    • mv707
                      • Jun 2023
                      • 21
                      • Azerbaijan
                      Boardview VSGS-GS
                      thanks
                      • Pipolups
                        Corsair K70 LUX RGB dying LEDs
                        by Pipolups
                        Hi there !
                        I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                        Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                        10-08-2024, 11:58 AM
                      • TinkerTron
                        Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                        by TinkerTron
                        Hey everyone,
                        I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                        Instead, here's what's been bugging me so far:
                        The schematic...
                        03-06-2025, 02:03 PM
                      • atunguyd
                        Acer x163w Monitor PSU schematic
                        by atunguyd
                        Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                        The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                        03-05-2025, 02:08 PM
                      • ShadowAi
                        ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                        by ShadowAi
                        Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                        Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                        After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                        03-15-2024, 10:46 AM
                      • Thetechdude
                        MSI Ventus RTX 4080 16G Broadview schematic needed
                        by Thetechdude
                        Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                        I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                        Thanks.
                        07-15-2025, 11:15 AM
