please any have this schematic, the problem is the display leds no activation.
					vgsg mb rev:2.1 schematic
 Re: vgsg mb rev:2.1 schematic
 Boardview VSGS-GSComment
 you can use BOARDVIEW software
 .. BTW anyone have access to schematics of this board?
 i have 4 missing CAPS (i know that this maybe is not a big issue but seems that they are necessary for some sort of "filtering") ... the internal LED panel is not working (external with HDMI works fine)
 the missing caps are: C4540 C4539 C4535C4536
 i can't find any other missing component (and there are broken soldering pads only for these 4 caps looking with the microscope)
 they are probably removed by plastic back cover of the laptop during battery replacement
 (looking at theboard view these caps are connected to CPU and to DISPLAYCABLE)Comment
			by PipolupsHi there !
 I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
 Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...10-08-2024, 11:58 AM
			by TinkerTronHey everyone,
 I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
 Instead, here's what's been bugging me so far:
 The schematic...3 Photos-
			by atunguydIi wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
 The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...-
							Channel: Schematics and Boardviews
			by ShadowAiHello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
 Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
 After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
			by ThetechdudeHi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
 I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
 Thanks.-
- Loading...
