DAOY61MB6EO Schematic
  • Karif
    • Oct 2015
    • Kenya
    I have this HP pavillion x360 laptop it will not power but seems to be charging the battery. When i press power button sometimes power led blinks briefly but does not power on.
    Anyone with the schematic for the m/b please would appreciate.
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: DAOY61MB6EO Schematic
    Here you go:
    • Karif
      • Oct 2015
      • Kenya
      Thanks alot much appreciated meritosari.
      • eng.umair.a
        • Jun 2016
        • 79
        • Pakistan
        Thanks a lot mate
        • sipokoyto
          • Sep 2016
          please allow me to post it here. i am also in need of schematic diagram for an Hp Pavilion DA0Y72MB6CO. This is for the model 13-A040ca.Thanks for the help.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
            03-31-2024, 02:12 PM
          • Russ1
            Starlink GEN2 Router Internal Power Supply Chicony UTP-211C Schematic
            by Russ1
            Sick of seeing big numbers of these routers dead no power light underneath.....
            Chasing Schematic of this power supply I have searched high and low....
            Already spotted a few swollen caps, but Ac fuse ok.....
            This is a dual output 50Vdc 2.5A and 12Vdc 1.25A psu
            Can anyone help with any type of schematic and parts list ?
            Thanks and Regards, Russ
            07-10-2025, 11:01 PM
          • valvashon
            Insignia NS-LCD-19-09: 5 blinks on power up
            by valvashon
            I'm needing some smaller OTA TV's for a monitoring project and this Insignia was $20 through FB Marketplace. It gives 5 blinks of the red LED when plugged in and 6 or 7, depending on how you want to count it, when powering down with the switch.
            Initial research points to a power supply issue but the two rails check to 5.06 volts and 12.22 volts. All electrolytics in power supply board checked to within 5% of the rated value. Some were high, some were low as checked with a super cheap off-brand cap checker that seems to be accurate. Can get pics and values tomorrow if anybody wants...
            11-07-2022, 04:42 PM
