DAOY61MB6EO Schematic
  • Karif
    • Oct 2015
    • 3
    • Kenya
    I have this HP pavillion x360 laptop it will not power but seems to be charging the battery. When i press power button sometimes power led blinks briefly but does not power on.
    Anyone with the schematic for the m/b please would appreciate.
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: DAOY61MB6EO Schematic
    Here you go:
    • Karif
      • Oct 2015
      • 3
      • Kenya
      Thanks alot much appreciated meritosari.
      • eng.umair.a
        • Jun 2016
        • 79
        • Pakistan
        Thanks a lot mate
        • sipokoyto
          • Sep 2016
          please allow me to post it here. i am also in need of schematic diagram for an Hp Pavilion DA0Y72MB6CO. This is for the model 13-A040ca.Thanks for the help.
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
            by sam_sam_sam
            03-31-2024, 02:12 PM
          • valvashon
            Insignia NS-LCD-19-09: 5 blinks on power up
            by valvashon
            I'm needing some smaller OTA TV's for a monitoring project and this Insignia was $20 through FB Marketplace. It gives 5 blinks of the red LED when plugged in and 6 or 7, depending on how you want to count it, when powering down with the switch.
            Initial research points to a power supply issue but the two rails check to 5.06 volts and 12.22 volts. All electrolytics in power supply board checked to within 5% of the rated value. Some were high, some were low as checked with a super cheap off-brand cap checker that seems to be accurate. Can get pics and values tomorrow if anybody wants...
            11-07-2022, 04:42 PM
          • meraklinetx
            Asus Z97-a power cycle, no boot no cpu voltage
            by meraklinetx
            Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
            05-10-2023, 06:08 AM
