Good Morning. (Where I am anyway.) Have Macbook Air 1398 with 820-00138-A with liquid damage. Does anyone have schematic and boardview for this board. Thanks in advance for any help.
820-00138-a A1398
Re: 820-00138-a A1398
I've got a schematic, no boardview though.Attached Files -
I'm working on a 820-00138-A board that was liquid damaged.
It's booting but goes into panic-mode (loud fans) and the cpu and ram is getting very hot.
I have 19,6V on PPBUS_G3H, this is too much, it should be 12v.
Does anyone has any idea what I can do next?
Thank youComment
Shorted high side MOSFET for the PPBUS_G3H buck converter, so you get the DC in voltage on PPBUS_G3H.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
Thanks but the board view you provide is a bit different than 820-00138-A board I have and the tracks doesn't match, in special ti the SSD control IC's side. Does anyone has the correct brd for this board please. Thanks in advance.Comment
have a problem with the trackpad not responding. try w another but nothing. guess is a problem w the logic board. any suggestions or someone with the right pdf and openview files..Comment
Schematics in this thread is the correct one. The touchpad connector J4801 in the schematics is wrong though, use 820-00163 schematics for the proper pinout.
The boardview in this thread is for 820-3662, it looks similar to 820-00138 but the SPI ROM and touchpad area are different. Use 820-00163 again to troubleshoot touchpad area.
The correct 820-00138 boardview may be available, but I haven't seen it yet. Most websites sell the 820-3662 but labelled 820-00138, be aware of this scam… (same for 820-3536 sold as 820-3476, 820-00163 sold as 820-00426 and maybe some others)OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
by kurlandHi,
I'm fixing a GPU card for a streamer, was sent to me by mail. A shorted cap on a power rail has severely burned the PCB.
As you can see from the darkened PCB around the mosfets there are signs of liquid damage. But it's odd because the person says no water has entered the PC cabinet. If you spill something on a desktop you would know I guess...
Funny thing is that the liquid is not only on the PCB but on top of many chips which are tightly covered by thermal padding under the heatsink, even on top of some of the RAM chips
by HondamanI hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
(After previous generation hardware [Gigabyte] didn't...-
by Fam787I bought a second hand Mid 2014 A1398 MacBook Pro when I lived in Australia. I'd bought it as a back-up machine because I had a Mid 2014 MacBook Pro, and realising it might one day fail, I wanted a backup machine because I don't like change.
Two weeks after buying MBP2, the seller called me to check if everything was OK with the unit, which I thought was odd. At that stage I might have turned it on a couple of times, but I'd not used it when he'd called. Over the last few years I used the machine seldomly because my original mac has been pretty OK. Every 3-6 months I'd charge it...5 Photos12-27-2024, 05:19 PM -
by JaneI would like to repair faulty backlight in Philips TV. In various videos, guys use a liquid before using a suction tool.
Can anyone let me know what kind of the liquid is it? Or what liquid do you use?
Thank you
Here is a video
https://www.youtube.com/watch?v=XzFT-o64jDQ -
by bloodhoundHi!
I´ve got an Acer C27-1655 AiO computer for repair on my bench.
Mainboard: AX1T_MAIN_PCB
The liquid was mainly in the area of MQ1, the voltage regulator for +VDDQ_MEM (pictures attached).
Symptoms:
When power is connected and power switch is pressed, I get 5V at L1, 3.3V at L2 and 1.8V at LPM5. I also get V1.05A_BYPASS at R442 for PCH.
I also measure 2V on +V1.8U_2.5U_MEM but +VDDQ_VTT and +VDDQ_MEM stay at 0V. +V1.8U_2.5U_MEM is also drawn to 0V if RAM memory is installed.
LPM1, LPM2 and LPM3 stay at 0V.
+VDDQ_MEM... - Loading...
