Liquid cooling?
This topic has been answered.
  • Hondaman
    • Sep 2008
    • 1075
    Liquid cooling?
    I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
    (After previous generation hardware [Gigabyte] didn't handle "maxing out" the VRM chips very well, I wanted something over-engineered, so I got this board, since it can handle the AMD 195W chip [9150 CPU?]) so my new VRM would be over-engineered.)
    (Right now, moving from 64 GB to 32 GB SEEMS to have fixed the rebooting problem. We'll see. EDIT: No, it is still rebooting randomly. Win AND Lin. Many times it will reboot after less than 5 minutes.)
    If this continues, well, I have two more NIB (new in box) motherboards of this same model (bought them years ago when you could get them new. Win7 piracy detection won't even see it as "new hardware"). Should I get liquid cooling for the CPU next time? If I did this, there would be no airflow from the CPU cooler to disturb the air getting to the VRM heat sink. The airflow onto the VRM would be a "blank slate". It would be zero, so I could rig up fans to blow VERY MUCH air onto the VRM chips and out the top of the case. Should I try liquid CPU cooling here? Even though everything is running at STOCK speeds, and always has been?
    Also, is it possible for liquid VRM cooling, or is that too motherboard-specific?
  • Answer selected by Hondaman at Yesterday, 10:58 PM.
    Hondaman
    • Sep 2008
    • 1075
    Thank you. It looks like I found the problem. The Seasonic Fanless 460 (it was not the 400) was apparently having heat-related problems.
    I moved the Seasonic Fanless 460 to the AMD 5350 system running the pfSense BSD-based ad-blocker (much lighter load). The PSU that was in the AMD / pfSense system was the Seasonic M12 "eye-eye" 520W. I don't do "roman numbers", so that is how I say it. That PSU is now in my "problematic" AMD 8150 Win7 system. I have been running Youtube for HOURS now, and there is no rebooting.
    I just read an old review of that Seasonic Fanless 460 from about 2012/2013 when it was manufactured, and they mentioned that you do need good case ventilation. So if I want to put it back in the AMD 8150 system, I will have to attach a fan to the top of my fanless PSU. Perhaps a 120mm fan, or maybe I would cut a cardboard "mask" to use an 80mm fan.
    Very few of my PSUs have actually have eight-pin motherboard connectors. I have a "Cooler Master" and a "Mad Dog Multimedia" PSU. They do NOT have 8-pin motherboard connectors, and also have poor quality. I might do well to get another Seasonic, or MAYBE two, while they still have that connector. And of course those Fractal Design tower cases.
    Probably my "bad" motherboard (which is in another bedroom) is just fine (I will keep it in my basement). Although I should still rig up some 80mm fans for the VRM and bridge chips on the AsRock 970A-G/3.1, just because I can. And it MIGHT prolong the life of these boards.
    Thanks!
      • 31080
      get a bootable image of memtest86+ and run it for a few hours
      or install it in your linux partition and it will be added to the bootmenu
      • Hondaman
        • Sep 2008
        • 1075
        Posting from my Galaxy S10+. One of the wires to the speaker was loose on that old motherboard, but I don't think there would have been any BIOS beeps anyway. Not sure about temperature alarms.
        I'm trying to install Ubuntu 24.04 or Mint 18.3 KDE on a spare AMD 5350 system (system on a chip, 17cm by 17cm board), they won't install for some reason. I need a "full featured" second system while I repair the first.
        I can't find the factory AMD heat sink / fan for the 8150 chip, so I'm stuck, and I cannot really proceed. Unless I can shop for a down-blowing fan from my phone, or install Linux on a P5GC/MX1333 board from my basement and dig myself out of this mess.
        I don't want to use the "BARAM" HS / fan (like a typical 120mm "upright fan" cooler) on the new board if I can avoid it.
        • lti
          • May 2011
          • 2551
          I would also recommend running Memtest86+ first.
          If you think it's a heat problem, the quick way to check is to open the case and have some kind of house fan blowing into it. Almost all down-blowing heatsinks still in production are either extremely thin (1U height) or so large that they hang over the RAM slots, so finding a replacement won't be easy. Maybe you could remove the stupid lights from a Wraith Prism (it still uses the old-style clip, so it will fit on anything socket 754 or newer).
          • Hondaman
            • Sep 2008
            • 1075
            Well that was interesting. Crossover Office (under Mint 21.3) did not work with Office 97, but it did work with Office 03, which is all I needed. It turns out my case won't handle a 120mm radiator. I should probably get 2 of the Fractal Design Refine R5, since I still occasionally use an optical drive.
            Posting from Windows 7, one of the AsRock 970A-G/3.1 boards I had in my basement. The eBay board I got a few weeks ago was junk, as I thought it would be. Never spend money on eBay that you cannot afford to lose.
            For now, I can retire the AMD 5350 with Mint 21.3 that I was using as a backup computer.
            When I move everything over to the Fractal Design case, I can shoot 80mm fans at the VRM and the bridge chips (it will look goofy, using the same wire as I use for 28-volt thermostat wire inside my walls or an old US land-line telephone, to hold the fans in place, but I will do it). And use Windows 7 as little as possible (DVD Decrypter, Media Monkey, CanoScan 8400 flatbed scanner).
            It is possible that I damaged the bridge chips on the AsRock by suddenly going all the way to 64 GB of RAM. Many of those old Dell / Intel boards could handle 4 GB Ram, but Dell never equipped them with more than 2 GB, so the bridge chips would not get as hot. Well, that's what I read on the internet.
            The second Fractal Design Refine R5 will be used for my new "main" Linux-only computer. In another thread, I discussed getting a Win10/11 computer for my mother. I might use hardware from that thread. Although for simple spreadsheets and e-mail, I will probably try to use my Radeon 7770. The fastest video card ever made that can still use completely passive cooling!
            If you think it's a heat problem.....
            It probably was a heat problem. Was it the VRM or the bridge chips? And how do I get enough air onto those specific heatsinks? Even with my new liquid-cooling setup, it might be quite difficult. I'll just use the AsRock 970A / Win7 hardware as little as possible, and my new modern Linux hardware 99% of the time (or if I wanted to, I could switch from the 125W AMD CPU down to 95W or even lower, but I might need a new Win7 key, which I bought last month). I have used Linux since 07-16-1998. I thought Mandriva 2010.2 worked well and had a great interface. Today's nice green interface of Mint is also pleasing.
            Ironic that my plan now includes the fastest passive cooled video card (Radeon 7770) and either the second or third fastest (Radeon 6660 or 6670) which I have in the Win7 machine. The one that I am not using here (6660 or 6670) is in Cincinnati on my mother's Win7 machine. So I own all 3 of the fastest passive cooled cards!
            No, the Fractal Design Define R5 WINDOW is not available anymore. But the regular Define R5 lets me open the hinge on the front of the tower and use the optical drive. It is a good enough solution. And there is no logo on the front. Just like the LACK of pinstriping or body side moulding on my 00-02 Saturn "S" series cars, the "plain" appearance of the front of the Define R5 is nice and elegant.
            Thanks for all your help !
            EDIT: I bought a KVM (keyboard / video / mouse) switch years ago, and it will be very useful here.
              • 31080
              how to get air to a heatsink? - hoses to direct from a remote fan on the front or side.
              when i was running 32bit athlons i used to mount a fan on the side panel so when it was closed it was above the heatsink.
              • lti
                • May 2011
                • 2551
                I remember Intel's spec for putting an air duct on the side panel to give the tiny P4 stock coolers fresh air. In-Win still makes those old cases, but they put modern front USB on them.
                The memory controller is integrated into the CPU on newer stuff like this, so I don't think a RAM upgrade would have damaged the motherboard chipset.
                I've been thinking about making some changes to my former main desktop (i5-8500 on a Gigabyte H370 HD3) as well. It's going to be a dedicated Windows machine since Windows wiped the bootloader from my Linux drive (both drives have Windows Boot Manager on them now) outside of an update cycle. Since I moved it into a different case (a Silverstone with 5.25" bays, but it's really shallow and difficult to work in), I've noticed a high-pitched whine at some CPU fan speeds. I'm thinking of getting a Thermalright AXP90-X53. The only tall coolers in that style (one from Evercool/StarTech and a few from Dynatron) cost more and might perform worse.
                I was going to hand that i5 down to my parents since their computer won't run Windows 11 without bypassing the CPU check and I don't think they could handle Linux. However, the amount of heat my new Ryzen is dumping out makes me reconsider. I might be imagining, but it really feels like it's heating the room up more than a "65W TDP" CPU with integrated graphics should. I won't rule out bad BIOS defaults cooking the CPU yet, but I think I'm going to be switching to older hardware to get better efficiency (which shouldn't happen, but I see efficiency dropping in general in all modern products - I've had rants about that before).
                • Hondaman
                  • Sep 2008
                  • 1075
                  I still have some green plastic "ductwork" leading to a fan on the back of the computer from an old Dell Dimension or maybe that old Pentium-750 that someone gave me one time. I could build some ductwork to direct air with cardboard and glue. It might be difficult to attach inside the case (and not very attractive) but it would work.
                  Looking at my spreadsheet with OpenOffice, it is not quite WYSIWYG. Office 03 inside of the Crossover product IS exactly like Windows. I'm using a family budget spreadsheet from simpleplanning dot net.
                    • 31080
                    something wrong with Libre-office?
                    • lti
                      • May 2011
                      • 2551
                      I don't think OpenOffice has had any meaningful updates in over a decade, but it's still an "active" project. LibreOffice is actually being developed, but it's a little broken compared to Office.
                      I would think that Office 2003 would run under Wine. I doubt that modern Office releases would, so I have a totally legitimate copy of Office 2016 (because Microsoft is a great company that respects their users and deserves more of my money) in a VM.
                      • Hondaman
                        • Sep 2008
                        • 1075
                        I was looking at it with Libre Office, which came with Mint 21.3. I typed "OpenOffice" by mistake. And with Libre Office, the fonts and appearance are not quite as polished as Office under Win7 or Office under Crossover.
                          • 31080
                          the font difference may be because the font is not installed, the standard windows font is not in linux unless you install it.
                          this effects wine.
                          • Hondaman
                            • Sep 2008
                            • 1075
                            Thank you. I do remember choosing to install extra font packages years ago, I'll have to look into it.
                            Guess what just happened to my new board? Random reboots after a couple of hours of use. Am I pushing my memory controller too hard? Is the north bridge or south bridge heat sink too small? Should I move down to an AMD 4100 or 4200 chip to go to from the 125W CPU to the 95W CPU? Does this mean the AsRock 970A board that "failed" a few months ago really did NOT fail, but a chip simply overheated out of spec? Maybe using the 16 GB DDR3 RAM modules (NON-ECC) is not TRULY supported, even though the motherboard manual says it really is supported?
                            I have not installed any fans or ductwork yet. Thank heavens I've got the AMD 5350 Mint 21.3 I can use as a backup machine.
                            I remember when you tried to switch the original IBM PC (10 megabyte 5.25" FH hard disk!) into "graphics mode", when all it had was 80 by 25 text mode. The computer would make a "click" sound, and the monitor would go dark. The only thing you could do was flip the switch on the PSU. But at least then you KNEW you did something wrong. These days, I don't think the software is doing anything wrong. It's the hardware.
                            I guess I'll try going from 32 GB RAM down to 16 or even 12, and install fans, and see if this fixes anything.
                              • 31080
                              is your psu good?
                              • Hondaman
                                • Sep 2008
                                • 1075
                                Thank you.
                                My Seasonic Fanless 400 is old, but it sat unused in my house for quite a few years. I have the equipment lying around to measure power consumption, but I do not think the PSU is overloaded.
                                So I really don't think that is the problem, but at this point I simply MUST try another PSU. It could be the problem, after all.
                                It looks like the PSU review site "realhardtechx" won't let me see their database anymore unless I allow them to send notifications to my browser anytime they want. I refuse. I am typing this on my AMD 5350/Mint system. Perhaps I can install another user on this system, then allow notifications, then delete the user immediately after.
                                  • 31080
                                  Seasonic = good shit.
                                  it's alli buy
                                  • Hondaman
                                    • Sep 2008
                                    • 1075
                                    Thanks!
                                    • Ace Perception
                                      Samsung R530 Bremen motherboard cooling
                                      by Ace Perception
                                      I'm wondering if anybody out there has much knowledge of Samsung Bremen motherboards.
                                      I've got a Samsung R530 which is about 10 years old, over the last 12 months it developed a worsening problem where when asked to do much work it would shut itself down. I had a good idea this was due to overheating which was confirmed by a temperature monitor programme which showed little balls of fire next to the various internal temperature readings. I could also prevent it shutting down if I placed a huge fan running at full speed in front of its air intake!
                                      So I went in pursuit of...
                                      07-21-2020, 03:05 PM
                                    • silver60618
                                      How to clean Liquid Metal from under CPU?
                                      by silver60618
                                      Hi all, Im working on a board, that my customer brought to another shop, and smeared liquid metal all over the board.
                                      The laptop powers on, then shuts off. I noticed traces of Liquid Metal near the edge of the CPU, but I fear some maybe underneath.
                                      Has anyone ever tried Ultrasonic cleaning, or compressed air to remove or agitate the liquid metal?
                                      07-11-2025, 01:47 PM
                                    • BleedCap
                                      OLD Socket 478 custom bracket + NEW generic cooler
                                      by BleedCap
                                      I already posted this on vogons.
                                      Its a 3d printed custom bracket for socket 478.
                                      I used this AM4 bracket as a base design.
                                      Its to be use with cheap generic clip based cpu cooler.
                                      Reason for doing this is:
                                      - Its hard to get/find a good copper base cooler. Even if you find one, the price is ....
                                      - New generic cooler is cheaper and can use bigger fan (less noise)
                                      I tested the bracket with cheap chinese horizontal cooler + fan taken from CM hyper 212 evo.
                                      The processor that I was using is P4 2.4Ghz prescott....
                                      11-05-2023, 08:09 PM
                                    • mitchw
                                      MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
                                      by mitchw
                                      Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
                                      It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
                                      I quickly took it apart and washed the liquid residue off the mainboard.
                                      The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
                                      The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
                                      Now the laptop...
                                      07-16-2025, 07:55 AM
                                    • Jane
                                      What liquid to use
                                      by Jane
                                      I would like to repair faulty backlight in Philips TV. In various videos, guys use a liquid before using a suction tool.
                                      Can anyone let me know what kind of the liquid is it? Or what liquid do you use?
                                      Thank you
                                      Here is a video
                                      https://www.youtube.com/watch?v=XzFT-o64jDQ
                                      02-15-2024, 05:51 AM
