Good Morning. (Where I am anyway.) Have Macbook Air 1398 with 820-00138-A with liquid damage. Does anyone have schematic and boardview for this board. Thanks in advance for any help.
					820-00138-a A1398
 Re: 820-00138-a A1398
 I've got a schematic, no boardview though.Attached Files
 I'm working on a 820-00138-A board that was liquid damaged.
 It's booting but goes into panic-mode (loud fans) and the cpu and ram is getting very hot.
 I have 19,6V on PPBUS_G3H, this is too much, it should be 12v.
 Does anyone has any idea what I can do next?
 Thank youComment
 Shorted high side MOSFET for the PPBUS_G3H buck converter, so you get the DC in voltage on PPBUS_G3H.OpenBoardView ā https://github.com/OpenBoardView/OpenBoardViewComment
 Thanks but the board view you provide is a bit different than 820-00138-A board I have and the tracks doesn't match, in special ti the SSD control IC's side. Does anyone has the correct brd for this board please. Thanks in advance.Comment
 have a problem with the trackpad not responding. try w another but nothing. guess is a problem w the logic board. any suggestions or someone with the right pdf and openview files..  Comment
 Schematics in this thread is the correct one. The touchpad connector J4801 in the schematics is wrong though, use 820-00163 schematics for the proper pinout.
 The boardview in this thread is for 820-3662, it looks similar to 820-00138 but the SPI ROM and touchpad area are different. Use 820-00163 again to troubleshoot touchpad area.
 The correct 820-00138 boardview may be available, but I haven't seen it yet. Most websites sell the 820-3662 but labelled 820-00138, be aware of this scam… (same for 820-3536 sold as 820-3476, 820-00163 sold as 820-00426 and maybe some others)OpenBoardView ā https://github.com/OpenBoardView/OpenBoardViewComment
			by silver60618Hi all, Im working on a board, that my customer brought to another shop, and smeared liquid metal all over the board.
 The laptop powers on, then shuts off. I noticed traces of Liquid Metal near the edge of the CPU, but I fear some maybe underneath.
 Has anyone ever tried Ultrasonic cleaning, or compressed air to remove or agitate the liquid metal?-
 07-11-2025, 01:47 PM
			by HondamanI hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
 (After previous generation hardware [Gigabyte] didn't...-
			by kurlandHi,
 I'm fixing a GPU card for a streamer, was sent to me by mail. A shorted cap on a power rail has severely burned the PCB.
 As you can see from the darkened PCB around the mosfets there are signs of liquid damage. But it's odd because the person says no water has entered the PC cabinet. If you spill something on a desktop you would know I guess...
 Funny thing is that the liquid is not only on the PCB but on top of many chips which are tightly covered by thermal padding under the heatsink, even on top of some of the RAM chips
			by Fam787I bought a second hand Mid 2014 A1398 MacBook Pro when I lived in Australia. I'd bought it as a back-up machine because I had a Mid 2014 MacBook Pro, and realising it might one day fail, I wanted a backup machine because I don't like change.
 Two weeks after buying MBP2, the seller called me to check if everything was OK with the unit, which I thought was odd. At that stage I might have turned it on a couple of times, but I'd not used it when he'd called. Over the last few years I used the machine seldomly because my original mac has been pretty OK. Every 3-6 months I'd charge it...5 Photos12-27-2024, 05:19 PM
			by mitchwGot a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
 It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
 I quickly took it apart and washed the liquid residue off the mainboard.
 The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
 The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
 Now the laptop...
- Loading...
