HELP! A1398 Dead,
  • Fam787
    • Dec 2024
    • 7
    • Ireland
    HELP! A1398 Dead,
    I bought a second hand Mid 2014 A1398 MacBook Pro when I lived in Australia. I'd bought it as a back-up machine because I had a Mid 2014 MacBook Pro, and realising it might one day fail, I wanted a backup machine because I don't like change.
    Two weeks after buying MBP2, the seller called me to check if everything was OK with the unit, which I thought was odd. At that stage I might have turned it on a couple of times, but I'd not used it when he'd called. Over the last few years I used the machine seldomly because my original mac has been pretty OK. Every 3-6 months I'd charge it and turn it on.
    When I would use it for a day or two, I noticed a problem with it waking up. Sometimes it'd not wake up, but it always eventually did, and I had no sequence of what woke it up, it was either the power button or closing and opining the screen, but because I hardly ever used it, it never bothered me that it had this issue. A few weeks back MBP2 started to do a boot loop on the chime. I disconnected the battery and it booted off the charger, worked fine, but throttled as MBPs do when only the charger is connected. I had only just recently started to use it more. Not much, just more than once every month or so.
    I ordered a new battery, but after fitting the new battery the machine was still chime boot looping. I thought the new battery might have been a dud, and the battery seller (kindly) sent me a replacement, but the machine was still boot loop chiming. I consulted with Gpt and provided it with information about the boot up problem. It had me boot into safe mode (I think) and there was a Windows boot drive reference I'd not been aware of, maybe a partition for a virtual machine, I am not sure here because I have some memory issues (brain injury).
    When I asked Gpt for advice it suggested cleaning out the windows boot partition that it seen in a screenshot I'd provided it. Gpt suggested an SMC and NVRAM reset, so I did what it asked including running the command
    sudo nvram -c, but when I tried to re-boot the machine it was dead. No keystroke option has worked to restart the machine since I deleted the window partition reference and completed the smc reset and ran the Nvram command. The last thing before it died was the Nvram command.
    I have tried all of the start-up combinations and tricks that I've read across 5 different forums. I can barely use a multimeter but checked the board and it seems from the rails I checked on that those rails have the right power, but my checks were very limited. I read that unplugging all the board peripherals and trying to start the machine might work, but nothing. I unplugged the IO board and tried a restart, but even after unplugging everything but the keyboard (and then including the keyboard) I got no start, dead. All that happens is that the fans spin weakly. No matter what button combination the fans spin weakly. Shift+Ctrl+Option+Cmd +Pwr let go of the power, charger goes from orange to green, but only the weak fans.
    I've read it could be the Vcore or SMC, and I could replace the SMC chip, but I didn't want to rush in. And I feel it might not be the SMC. I have only a soldering iron, no hot air. I am trying to fix this myself because I am poor, it's as simple and embarrassing as that.
    Somebody else on this forum seemed to have a very similar problem, and I think they flashed the efi, but I am not sure about how to go about that. I have the equipment to flash a chip. I've included pics of the numbers on my board. Even though it says it's an A1398 on the case, I am not so sure about the board. I've included a pic of the top and bottom of the board. I apologise for being a noob, and I do have some skills, but I am not a tech, more like somebody who can follow instructions and who most times can fix things. ALL HELP is received with offerings to the gods for your long life and good health. I also took close up pics of the numbers on the board. Apologies if I've made a mistake by posting here. I'm firstly trying to confirm the MBP model I have, like if it is an A1398, and then I will try to get a brd file, and then I'd post to get help with diagnosing the problem, but (I feel) the first thing is to identify the board and get the correct drawings. I downloaded and installed boardview on my original mac.
  • double_DD
    Transformer replacement for a dead coffee machine
    by double_DD
    Hi guys,
    I have a dead coffee machine, and it seems that the culprit (no 1, at least) is a dead trafo - primary coil seems to be blown open (type shown on the picture below).
    Now, I'm unable to find direct replacement anywhere on ebay or aliexpress, and all similar that I' was able to find are rated too low (<1A).
    If someone knows a shop to buy replacement (EU/CH), that would of course be my 1st option.
    My other ideas:
    - to buy 220/20Vac trafo with 30VA, and to "manually" create secondary 12V output just via resistor
    - to buy...
    06-23-2025, 05:43 AM
  • privato89
    Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
    by privato89
    I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
    Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
    Let's begin:
    Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
    03-26-2024, 06:37 AM
  • madan1
    Cisco catalyst 2960c POE
    by madan1
    Hello everyone.
    Got a catalyst 2960 from the usual scrapyard - ebay.
    It is stuck in bootloop and the power supply is missing the 3.3v rail. (+12V, -53V, +3.3V)
    Some green moisture crystallization on mainboard, which cleared very well with IPA and visually there is nothing rusted or gone.
    Still working on the PSU to get the 3.3v rail back (waiting for parts), but for now I'm using an external buck converter board hooked up to the 12V rail ( by the way, the switch seems to be working with only 12V ).
    The switch fails to boot due to the following POST error:...
    12-19-2024, 09:34 AM
  • survivalbloke
    Macbook A1398 - no startup chime, no boot, but have fans and CPU warm
    by survivalbloke
    Macbook A1398 - had repeating loop of startup chime with no actual boot. Just startup chime, then restart, start up chime, then restart, etc. I pulled the battery and cleared BIOS. It will now power up, fans on, CPU warming, but no startup chime and no boot. I reflashed the BIOS chip but the same thing happening. Where should I go from here?
    06-14-2023, 11:45 AM
  • Luke Anders
    Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
    by Luke Anders
    A few details about the laptop itself:
    Name: Lenovo Legion 5
    Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
    BIOS Version: GKCN60WW
    EC Version: GKEC65WW
    Serial Number: PF39AQ7Z
    Board Model: NM-D562 Rev 3.0
    RAM: 16GB Installed, DDR4 (brand new)
    NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
    I bought this laptop recently from eBay as a faulty device....
    10-12-2024, 05:13 AM
