ASUS K52Jc No Power
  • DrawdeSoft
    • Jul 2016
    • 19
    • Philippines
    ASUS K52Jc No Power
    Hi Everyone! i have a problem with Asus K52J, it has no power but sometimes when i plugged in the chareger it becomes auto power on. Can i ask what must be the main cause? and i hope anyone can give me a schematic diagram :-) main board label is K52JC rev 2.0
    i hope someone could notice my post.. TIA
  • angel-boy
    • 550
    Re: ASUS K52Jc No Power
    https://cdn.badcaps-static.com/pdfs/...3a9e7f98b3.pdf
    or
    https://www.badcaps.net/forum/showthread.php?t=36264
    • DrawdeSoft
      • Jul 2016
      • 19
      • Philippines
      Hi Sir! i think ASUS K52JC is different from the link that u gave :-) i hope you can help me sir thanks a lot
      • samanthban
        • Feb 2014
        • 253
        • Sri lanka
        Finally I noticed your post sir This is the board view, it might help you.
        sigpic
        • DrawdeSoft
          • Jul 2016
          • 19
          • Philippines
          thanks for this one sir, but unfortunately i cant open the file? can i ask for pdf file sir if u dont mind :-) thanks for the help... really appeciate it
          • meritosari
            • Oct 2010
            • 774
            • Indonesia
            Software to open those file:
            https://www.badcaps.net/forum/showthread.php?t=56151
            http://boardviewer.net/index
            Schematic, not available
            • DrawdeSoft
              • Jul 2016
              • 19
              • Philippines
              tnx for the info sir
              • kiraro
                • Jan 2016
                • 177
                • North NY
                Do you solve your problem?if not ,check 19v on the fuse after the two beginning MOSFET ,if is present then check 3 v and 5v (always),if it isn't ,then check your charger ic (vin,acin,acok),sometimes there is a bad connexion on charger ic disoldering and soldering it again may solve problem ,(but not always) you should check 19 v on the fuse after the two switch if isn't present check acin (3,3v) a divider with two resistance if you don't have acin 3,3v the charger ic will not switch the second transistor to get 19 v on the fuse or resistance ( generally it called B+) also check the two first transistor if one of them defected and make sure B+ not shorted.
                Sorry for my bad English ,
                Hope that help you sir
                • see1001
                  elo
                  • Dec 2015
                  • 39
                  • turkey
                  thanks
                  • OldestGoat
                    • Oct 2018
                    I landed at this thread because my ASUS K52Jc suddenly began displaying a flashing orange LED near the touch pad instead of the normal steady green LED in that position. I performed all of the software related fixes that I could find on the net. The next indication was either a bad battery or a bad motherboard. At this point, since the symptoms were the same as no battery present, I took the step of removing the battery and at the rear of the computer I applied slight outward force to each of the two large blades related to the battery + and -. I reinserted the battery and the problem is resolved. Contact cleaner might have accomplished the same. So, I didn't need to replace any caps but I'm happy to have discovered this site dedicated to cap replacement. A very useful reference. Thank you one and all.
                    • fox01fox02
                      • Oct 2015
                      • 28
                      • iran
                      thanks a lot
                      • day_see
                        • Feb 2016
                        • 10
                        • TURKIYE
                        thanks
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                        • ShadowAi
                          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                          by ShadowAi
                          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                          03-15-2024, 10:46 AM
                        • meraklinetx
                          Asus Z97-a power cycle, no boot no cpu voltage
                          by meraklinetx
                          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                          05-10-2023, 06:08 AM
