Looking for ASUS X200MA motherboard Schematic
  • zion
    • Mar 2018
    • Philipines
    Need schematic for Asus x200ma
    HI good day to all!! I need schematic for asus x200ma rev 2.1
    my x200ma have n led light on display.. i checked already the flex and try other lcd but still same problem.. thanks
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      Re: Need schematic for Asus x200ma
      Boardview only:
      https://www.badcaps.net/forum/showpo...68&postcount=5
      This schematic quite close enough.
      https://www.badcaps.net/forum/showpo...2&postcount=16
      • HUSSAINGB
        • Oct 2018
        • UAE
        Re: need schematic asus x200ma
        Hi and thanks . I need shematice of this model too
        • lazyboi11
          • Dec 2014
          • 12
          • Philippines
          asus x200ma
          Hello everyone..
          I need an asus x200ma motherboard schematic...
          Can somebody share if they have one available?
          Thank you in advanced...
          • luisalexis
            • Aug 2020
            • En Salvador
            Originally posted by kuyakim
            x200ma rev 2.1 schematics i need this too pls upload
            Thanks a lot!
            • Jokowie
              • Oct 2022
              • 13
              • fire
              #26
              Re: Looking for ASUS X200MA motherboard Schematic
              • glovecaps
                by glovecaps
                11-25-2024, 04:23 PM
              • dhenion
                Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                by dhenion
                I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                The original board was:
                ASUS X510UNR REV 3.0 A
                The replacement board is:
                ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                01-30-2024, 01:45 PM
                ASUS P5GC-MX motherboard recap
                by momaka
                Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                So here is what the motherboard looked like with its original caps:
                CPU VRM area up close…...
                01-27-2021, 11:59 PM
              • MakNCheese
                ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
                by MakNCheese
                I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
                Symptoms:
                • Severe lag across the system, including BIOS navigation.
                • Slow boot times and unresponsive performance in Windows.
                • Battery charges very slowly (e.g., ~5% in 2–3 hours).
                • No error messages or BSODs, just extreme sluggishness.
                What I've Tried:
                • Replaced
                06-04-2025, 12:48 AM
              • EvazX
                ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                by EvazX
                I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                However, after some time, the replacement motherboard...
                08-25-2025, 06:09 PM
