HP G6-1189sa (DAR18DMB6D1 REV: D) No Power - schematic
  • FShahid
    • Nov 2012
    • 57
    Hi, I have this laptop and it wont show any signs of life. Disassembeled and the checked the boards for any physical damage there is none. This motherboard has Core i3 BGA soldered on board. When connecting charger there is slight clicking noise throughout the board.
    Tried to find the short on mosfets there are none in four pin mosfets, the board slights heats around PQ48 and the silver capacitors PC207 and PC208 (both of them showing continuity of value 2) also small capacitors EC1 EC2 EC3 and PC89 (maybe more) all showing same continuity value of 2 on other side of the board at same area. There must be a short somewhere there but couldn't find it.
    Kindly let me know what to check for, can't find the schematics, thanks.
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: HP G6-1189sa (DAR18DMB6D1 REV: D) No Power
    hope this help you
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      tnx
      Im Back... sort of...
      • Comrad_SU
        • Feb 2014
        • 31
        • Ukraine
        • Electronics
        Originally posted by meritosari
        hope this help you
        Thank You!
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • hartleyhare5
          Samsung QE65Q9FN — BN44-00944A (65A board) MOSFET failure (relay clicking on one connect) — advice before power-up
          by hartleyhare5
          Post body:
          I'm working on my Samsung QE65Q9FN (65" Q9FN QLED, European model) with relay clicking and no picture. The power supply board in the display itself is the BN44-00944A, known on the board itself as the 65A board (silk-screened designation). There is also a second board, the 65B, which looks identical but is only partly populated for the LED power.
          Symptom: Continuous relay clicking on the one connect — TV will not start up, no picture. However the standby LED is on constantly — so the standby supply rail appears to be alive and the...
          03-26-2026, 03:47 AM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • dom.true
          IC2960 for A Board - Panasonic TH-P42X10Z Plasma Television
          by dom.true
          Hi Folks,
          I have a Panasonic TH-P42X10Z Plasma Television (2009-era; New Zealand model).
          This set has proven to be extremely reliable throughout its +16-year lifespan. However, late last year, when going to use the TV, I noticed a 9-blink red LED error code on the front of the set after the television failed to turn on. A quick Google search revealed that this indicates a problem with the set’s main A-board.
          After opening up the set and giving the board a thorough test with my digital multimeter, I found that one of the integrated circuits on the board...
          01-17-2026, 05:01 PM
