Doubt in this diagram laptop.
  • saularciga
    • Feb 2014
    • 55
    • mexico
    Hello, I have a doubt in this diagram laptop.
    Annex picture. Could you tell me if it is normal the value of 2 ohms off the coils. The reading was taken without processor.
    That value should be?
  • khaahk
    • Dec 2013
    • 810
    • Estonia
    Re: Doubt in this diagram laptop.
    If measuring relative to gnd without cpu 2 ohms, then no. Should show high resistance.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      more than 5ohm. remove coil to locate short
      • saularciga
        • Feb 2014
        • 55
        • mexico
        OK, will remove coils, and will measure again.
        That value should be aproximadamente? 50 ohms or more ? 100 ohms
          2 Ohms measured between the two legs of the inductor? The DCR will be very low which is normal, if 2 Ohms against GND then is not normal.
          POWER MOSFET Q513, 516 may be bad or bad filter caps.
          • saularciga
            • Feb 2014
            • 55
            • mexico
            Ok. The mesure is if 2 Ohms against GND ,. Es very low. I removed Mosfet and the measure is the same.: 2 ohms. I will measure caps
              "I removed Mosfet and the measure is the same.: 2 ohms. I will measure caps" both Q513, and Q516?
              • saularciga
                • Feb 2014
                • 55
                • mexico
                Hi, removed all mosfet y the measure is the same : 2 ohms
                • rievax_60
                  • May 2012
                  • 897
                  • australia
                  Did you remove the coils? Normal resistance should be hundreds of ohms or higher.
                  • saularciga
                    • Feb 2014
                    • 55
                    • mexico
                    Hi... RESOLVED!!! C734 BAD .
                    MUCHAS GRACIAS A TODOS!!
                      Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                      This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                      09-06-2024, 09:30 PM
                      Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                      This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-06-2024, 08:47 AM
                    • RdeveLabs
                      MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                      by RdeveLabs
                      To all the members here...
                      Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                      So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                      05-05-2025, 04:59 AM
                      Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                      This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-07-2024, 06:11 AM
