cq 43 (amd)schematic needed
  • ranjanlaptop
    • Dec 2013
    • 207
    • india
    part no:657324-001 chicago_br_hpc mv_mb_v2
  • aanan
    • 222
    • India
    Re: cq 43 (amd)schematic needed
    i have this.
    • dj_ricoh
      • 2073
      can you post the problem of the notebook?
      maybe how you fix it?
      • Ramee
        • Jul 2014
        • 218
        • Israel
        Can you tell us the problem?
        • xurplusxhop
          • Jan 2012
          • 34
          hp 2000 (chicago_br_hpc mv_mb_v2)
          problem: no internal display, external display is ok.
          BL_ENABLE and LCDVCC is 0v.
          LVDS_PWM is 1.25v.
          • Ramee
            • Jul 2014
            • 218
            • Israel
            Make your own thread next time. Before you make a post tell us what did first.
            Did you try another screen/cable?
            • dj_ricoh
              • 2073
              LVDS_PWM is 1.25v.
              start a new post and see if you got on pin3 +3.3v
              • edeson2010
                • Nov 2015
                • 4
                • aswan
                thank you
                • Camus
                  • Aug 2016
                  • Ecuador
                  Quemado en la entrada de corriente, y no se que es lo que se quemo porque esta vacio es espacio.
                  ayudenme gracias
                  • Boys09
                    • May 2017
                    • 12
                    • Klaten
                    Thanks you
                    • fyaagoub
                      • Dec 2016
                      • 269
                      • maroc
                      Thanks you
                      • zafancom
                        • Sep 2017
                        • indonesia
                        thank you, and what password to open pdf?
                        • Dipraj Rasaily
                          • Apr 2018
                          • India
                          Need schematics of chicago_br_hpc mv_mb_v2
                          • Arif Hidayatulloh
                            • Jan 2019
                            • 3
                            • Jawa Barat
                            Thanks my broow
                            • G-Sting
                              iPad Pro A1876 SHORT Part Identify Help Needed
                              by G-Sting
                              So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                              So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                              i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                              SO My main concern is what part should i order what should i search the name for ?
                              on Ipad...
                              05-15-2025, 09:30 AM
                            • edugimeno
                              Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                              by edugimeno
                              Hi There!
                              I'm trying to help my friend who owns a restaurant be just bought.
                              He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                              It's stuck using, I guess, the 2 sided tape that comes with the strip
                              The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                              09-05-2024, 09:34 AM
                            • vbogoev
                              Lenovo S6000 won't turn on. Data recovery needed.
                              by vbogoev
                              Here I have the mentioned tablet with motherboard s6000-mb-h401. The tablet won't turn on, no display, charging normally. I manage to connect to UART port and got this output when I try to start it:
                              Code:
                              [PWRAP] pwrap_init_preloader
                              [PWRAP] pwrap_init
                              [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5
                              [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5
                              [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5
                              [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5
                              [PMIC_WRAP]wrap_init pass,the return
                              06-20-2023, 06:36 AM
                            • Goblin999
                              RTX 3060 EVGA - Part Discover Help Needed
                              by Goblin999
                              Hello , I have this 3060 EVGA card that doesn`t work . Measured for shorts and resistance , seems ok . Powered it up but doesn`t work , GPU chip is cold . Though this part circled in red is getting very hot and pretty fast so I suspect this is the reason . Can somebody help me discover what this part is . Maybe a data sheet or a similar part ? Thanks...
                              02-10-2022, 09:09 AM
                            • CraigR
                              Used PS5 part needed
                              by CraigR
                              Client decided to do his own repairs and knocked off this inductor coil. I can not find anyplace to purchase a new one and do not have a donor board so can someone sell me one off their donor board or give me a link to where I can purchase a new one? THANKS!...
                              06-19-2024, 02:29 PM
