RTX 3060 EVGA - Part Discover Help Needed
  • Goblin999
    • Jan 2022
    • 79
    • Romania
    Hello , I have this 3060 EVGA card that doesn`t work . Measured for shorts and resistance , seems ok . Powered it up but doesn`t work , GPU chip is cold . Though this part circled in red is getting very hot and pretty fast so I suspect this is the reason . Can somebody help me discover what this part is . Maybe a data sheet or a similar part ? Thanks
  • foshland
    • Jan 2017
    • 122
    • Spain
    Re: RTX 3060 EVGA - Part Discover Help Needed
    I think its a voltage regulator, put its code in aliexpress, try
    • Goblin999
      • Jan 2022
      • 79
      • Romania
      it only write CKCWT on that little chip and I cannot find anything about it , or a similar product .
      • Bozog
        • Jan 2022
        • 125
        It looks like its the 5v rail buck regulator, but on the only schematic I can see its a MP1475DJ which has different markings, so possibly an equivalent chip from a different manufacturer.
        • Goblin999
          • Jan 2022
          • 79
          • Romania
          do you have a boardview or schematics for this card ? I got no voltage on most rails unfortunately and I don`t know ehere to look .the only thing that I can notice is that that part is getting really hot and I presume that is the main factor
          • Bozog
            • Jan 2022
            • 125
            Yes 5V is usually the first rail to come up, so if you don't have that...I looked at this one from dicky96's discord server
            • Goblin999
              • Jan 2022
              • 79
              • Romania
              thanks
              • Bozog
                • Jan 2022
                • 125
                Surely tho, if there is no low resistance to ground on that 4r7 coil next to the hot chip, then the chip itself is faulty.
                • Goblin999
                  • Jan 2022
                  • 79
                  • Romania
                  actually it is a very low resistance on the coil near the hot chip - like a short - maybe it is a short somewhere and I cannot trace it (been measuring fuses and all seem good though)
                  • Goblin999
                    • Jan 2022
                    • 79
                    • Romania
                    measured here
                    • Bozog
                      • Jan 2022
                      • 125
                      Well ideally you would inject something like 0.8v@3a on this coil and see what gets hot, but you'd need a lab type power supply for that. This could just be a shorted capacitor, which you maybe able to spot on close inspection.
                      • Goblin999
                        • Jan 2022
                        • 79
                        • Romania
                        Luckily I have one
                        • Goblin999
                          • Jan 2022
                          • 79
                          • Romania
                          The same voltage regulator got hot around 3,5a on 0,9v
                          • Goblin999
                            • Jan 2022
                            • 79
                            • Romania
                            Now I need to find a part equivalent for that little buck regulator . Ali express shipping will take at least 4 weeks
                            • Goblin999
                              • Jan 2022
                              • 79
                              • Romania
                              Changed that little part but still nothing . I am blocked here with nowhere to go . This is what I got on multimeter
                              • Goblin999
                                • Jan 2022
                                • 79
                                • Romania
                                Another fact that I have discovered . All the pair lanes from the front of the card pcie measured in diode mode gives me the result 0 . I fear that the GPU chip is gone . If anybody knows better please tell me if it`s wrong or right
                                • eddgl
                                  • Mar 2022
                                  • 4
                                  • Mexico
                                  Hi Goblin Can you fix your EVGA ?
                                  i have exactly the same issue... i find that MP1475DJ doesnt get the Enable Voltaje, and the UP9516 #PART U14 "PEX SWITCHER" The same hasnt enable voltaje....
                                  i have order the 2 ICS and will change it.... i will publish my result asap
                                  • Goblin999
                                    • Jan 2022
                                    • 79
                                    • Romania
                                    I sent it to a friend in Slovenia who masters the GPU repair and he said that the GPU chip is bad , sadly...
                                    • G-Sting
                                      iPad Pro A1876 SHORT Part Identify Help Needed
                                      by G-Sting
                                      So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                                      So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                                      i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                                      SO My main concern is what part should i order what should i search the name for ?
                                      on Ipad...
                                      05-15-2025, 09:30 AM
                                      Thermal pad thickness for various laptop GPU / Graphics Cards
                                      ASUS Dual RTX 2070 OC 8GB
                                      ASUS ROG STRIX RTX 3080 OC
                                      ASUS ROG STRIX RTX 3090
                                      ASUS TUF Gaming RTX 3080 OC Edition
                                      ASUS TUF GTX 1660 S-O6G GAMING
                                      EVGA RTX 3060 Ti XC GAMING 8GB
                                      EVGA RTX 3060 XC GAMING 12GB GDDR6
                                      EVGA RTX 3080 FTW3 ULTRA GAMING
                                      EVGA RTX 3080 TI FTW3 ULTRA GAMING
                                      EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                                      Gainward RTX 2080 Phoenix GS Specs
                                      Gainward RTX 3070 Phoenix 8GB
                                      Gainward RTX 3080 Ti Phoenix
                                      GIGABYTE AORUS RTX 3080 MASTER 10G
                                      02-09-2024, 08:08 AM
                                    • Rayven
                                      EVGA GTX760SC Schematic Needed
                                      by Rayven
                                      hello everyone , im looking for a schematic file for a gpu card EVGA 760 SC , i already made measurements in many places and all looking good but i want to verificate the mos critics zones and verify routes , im going to atach an a PCB photo and if anyone have the file .fz , .brd or any technical reference please sended to me , i really apreciate any help .
                                      10-18-2025, 09:15 PM
                                      NVIDIA GeForce RTX 3060 Schematic & Board View
                                      The GeForce RTX 3060 12 GB is a performance-segment graphics card by NVIDIA, launched on January 12th, 2021. Built on the 8 nm process, and based on the GA106 graphics processor, in its GA106-300-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3060 12 GB. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA106 graphics processor is an average sized chip with a die area...
                                      10-02-2024, 08:03 AM
                                    • edugimeno
                                      Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                      by edugimeno
                                      Hi There!
                                      I'm trying to help my friend who owns a restaurant be just bought.
                                      He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                      It's stuck using, I guess, the 2 sided tape that comes with the strip
                                      The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                      09-05-2024, 09:34 AM
