part no:657324-001 chicago_br_hpc mv_mb_v2
cq 43 (amd)schematic needed
by G-StingSo My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
SO My main concern is what part should i order what should i search the name for ?
on Ipad...4 Photos -
by edugimenoHi There!
I'm trying to help my friend who owns a restaurant be just bought.
He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
It's stuck using, I guess, the 2 sided tape that comes with the strip
The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth... -
by vbogoevHello,
Here I have the mentioned tablet with motherboard s6000-mb-h401. The tablet won't turn on, no display, charging normally. I manage to connect to UART port and got this output when I try to start it:
...Code:[PWRAP] pwrap_init_preloader [PWRAP] pwrap_init [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5 [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5 [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5 [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5 [PMIC_WRAP]wrap_init pass,the return
by Goblin999Hello , I have this 3060 EVGA card that doesn`t work . Measured for shorts and resistance , seems ok . Powered it up but doesn`t work , GPU chip is cold . Though this part circled in red is getting very hot and pretty fast so I suspect this is the reason . Can somebody help me discover what this part is . Maybe a data sheet or a similar part ? Thanks...
by CraigRClient decided to do his own repairs and knocked off this inductor coil. I can not find anyplace to purchase a new one and do not have a donor board so can someone sell me one off their donor board or give me a link to where I can purchase a new one? THANKS!...
- Loading...
