Hp 630
This topic has been answered.
  • U.M.A tate
    • Jan 2025
    • 5
    • french
    Hp 630
    i need the schematic of Hp 630 notebook
    motherboard code: 646671-001
  • Answer selected by U.M.A tate at 05-18-2025, 09:27 AM.
    SMDFlea
    • 21861
    Originally posted by U.M.A tate
    No there isnt
    this one maybe https://www.s-manuals.com/motherboar...f101,_tpn-f102
      • 21861
      What is the motherboard model number.
      Beginner's guidelines
      https://www.badcaps.net/forum/troubl...r-s-guidelines
      1.1.3 Motherboard model number​
      • U.M.A tate
        • Jan 2025
        • 5
        • french
        well from i can read from the sticker under the ram slot the motherboard number is : 646671-001
        pc Model if that helps : Hp 630 TPN-F102
        Thank you for advance.
        • AL._.EX
          • Dec 2022
          • 896
          • Belarus
          https://www.badcaps.net/forum/troubl...p-hp630-cpu-i3
          • U.M.A tate
            • Jan 2025
            • 5
            • french
            Thanks for your help but its not the same motherboard i have thou the one i have has pentium cpu.
            • AL._.EX
              • Dec 2022
              • 896
              • Belarus
              This inscription is on the board: chicago_cp_hpc ?
              • U.M.A tate
                • Jan 2025
                • 5
                • french
                No there isnt
                  • 21861
                  No there isnt
                  • U.M.A tate
                    • Jan 2025
                    • 5
                    • french
                    Thank you so much that what i was looking for i appreciate it so much.
                    • Friend33
                      Changing BIOS Serial Number After Motherboard Replacement on EliteBook x360 G3
                      by Friend33
                      I have an EliteBook x360 G3 where I had to replace the motherboard. Everything is working fine and there are no errors during boot. However, I have the issue that the serial number in the BIOS is incorrect. When I run the DMI tool under Windows, I get an error stating that I am not in Unlocked Mode and therefore cannot make any changes. I was able to change the Asset Tag directly in the BIOS. Now I am wondering, can I simply read the BIOS chip, change the serial number with a hex editor, and write it back, or what other options do I have? The old motherboard did not work at...
                      06-16-2024, 03:13 PM
                    • piernov
                      by piernov
                      You have a laptop that does not power on, powers on but shows no image, crashes, etc… You want to fix it but you don't know where to start.
                      There are 2 situations:
                      1. You just want your laptop fixed
                      2. You want to learn about fixing laptops
                      Sorry, but if you're in situation number 1, we recommend you to use the services of a trustworthy professional repair shop.
                      Unfortunately, if you're not serious about learning, you will waste your time and money, and you will make us waste our time as well.
                      If you are in situation number 2, then please continue and...
                      09-20-2020, 09:46 AM
                    • sikocan
                      Lenovo X1 Carbon 9th Gen Black Screen
                      by sikocan
                      I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
                      SN: PF3G1REP
                      MODEL: 20KW-00J1AU
                      PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
                      Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
                      06-24-2025, 09:01 PM
                    • glovecaps
                      by glovecaps
                      11-25-2024, 04:23 PM
                    • Docus
                      Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                      by Docus
                      Hi everyone 😀,
                      I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                      To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                      Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                      1. I already own the exact same model, but its plastic chassis is badly damaged.
                      06-10-2025, 04:24 PM
