Looking for MSI MS16P61 schematic and boardwiew, I made a short circuit trying to replace the screen while the notebook was still turned on, and now it doesn't turn on
by LA1I am trying to find two smd datasheets for an Apevia 1000w prestige power supply ATX-PR1000W the SMD's are ST9S313 which is a SMPS supervisory chip and a EST 915HP or XP48024 not sure which or both is the chp prod number and the schematic
by fitz301Hello,
I'm really hoping somebody on this forum, who have way more expertise than I, can help me with something.
I am searching for the schematic to hopefully repair my 83 yr old mother's console stereo system, it's a 1979 Soundesign 5595 w/ turntable, AM/FM stereo receiver, cassette and 8-track tape, everything works but there's a loud bass hum when using the cassette player and the FM radio needs to be turned up to full volume to hear it, every other part seems to work like it should with the exception of burnt out dial lights and needing new belts.
I've been...-
I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
Well, my decice specs are the following:
Model: Acer Nitro 5 AN517-54-55T5
CPU: Intel Core i5-11400H
GPU: NVIDIA GeForce GTX 1650
Motherboard: GH51G LA-L181P Rev:1c
The symptom:
When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...05-26-2025, 10:49 AM -
by kodoxsince i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
what i've done:
- flashing... -
by RotVikHello everyone, I come here in search of wisdom and hope.
I got this laptop with charging problems, apparently it charged ok while turned off but it would not charge while powered on, anyways I was doing initial measurements looking at the voltaje on the ID Pin, it is a 135W DC Adapter and the pin actually measured 1.9V that looks ok, anyways, while doing that, I accidentally shorted the ID pin DETECT(ID) with one of the 20V pins, sparkles and it automatically killed the TVS Diode PD102, and also made a cute burning hole on the middle of the KBC or EC chip UE1, it is a IT8227E-128... - Loading...
