B1400CEPEY R2.1
  • ngger handoko
    • Mar 2024
    • 32
    • indonesia
    B1400CEPEY R2.1
    Excuse me, may i request schematic Asus expertbook B1400CEPEY R2.1,
    or maybe can help , B2 VND, <<<< this is P or N channel?
    thankyou.
    • 21874
    thankyou.
    Post a picture of it
    • ngger handoko
      • Mar 2024
      • 32
      • indonesia
      Mark with: B2 VNC
      6X0201
        • 21874
        Mark with: B2 VNC
        6X0201
        I`d say its a NIKO-SEMI mosfet,but i don`t know what the exact part number is yet https://www.badcaps.net/forum/troubl...86#post1672286
        • Bonzas
          • 472
          • Indonesia
          Here u go
            • 21874
            Originally posted by Bonzas
            Here u go
            Nice find ,i`ll add that one to the list
            • ngger handoko
              • Mar 2024
              • 32
              • indonesia
              Here u go
              thankyou
              • fichamba
                • Dec 2011
                • 134
                • Spain
                WOW! Thanks a lot, Bonzas!!!
                • eccerr0r
                  old X58 triple channel board... memtest86 memory speed?
                  by eccerr0r
                  Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                  Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                  Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                  06-28-2025, 09:06 AM
                • spleenharvester
                  Reverse engineering of 18650 4-channel tester
                  by spleenharvester
                  Hi friends
                  I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                  05-04-2025, 02:43 AM
                • mikey5791
                  Help on car amplifier only one channel works
                  by mikey5791
                  Hi all forum members,
                  Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                  My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                  08-06-2025, 10:36 PM
                • dicky96
                  American Audio VLP1500 Distorting on one channel
                  by dicky96
                  Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
                  Protection and Clip LED are off
                  There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
                  I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
                  The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
                  07-13-2022, 05:25 AM
                • dicky96
                  Hitachi V19B01922 Channel Tune problem
                  by dicky96
                  Hi Guys
                  I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                  He also has an LG TV, so three screens in the bar
                  I installed three Satlink ST-6503 DVB-T Modulators
                  This model https://www.aliexpress.com/item/32916553905.html
                  These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                  02-09-2023, 09:20 AM
