macbook a1990 820-01827-01
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    Please share the diagram and boardview for this model
  • mon2
    • 14657
    Apparently you can use 820-01041 for reference:
    820-01827-A - Sudden death - 19V missing all USB-C port | Rossmanngroup Forums
    • PITERPENY
      • Jul 2023
      • 461
      • Ukraine
      thanks for the recommendation
      • lgindia.subhash@gmail.com
        • Aug 2024
        • India
        820-1827-01 and 820-1814 both are same you can use it
        • fraig
          • Nov 2014
          • 36
          • cairo
          820-01827-A
          This board doesn't detect sensor
          Changed top and EDP cable but not working
          Any help
          What's tips to solve this board​
          • PITERPENY
            • Jul 2023
            • 461
            • Ukraine
            Originally posted by fraig
            820-01827-A
            Any help
            this model has a display sensor that is not connected to the edp, it is located separately on the display panel. try replacing it, they often do not work.
            • PITERPENY
              • Jul 2023
              • 461
              • Ukraine
              There is no separate diagram or boardview for this board, use the 820-01041-A schematic
              • fraig
                • Nov 2014
                • 36
                • cairo
                I THINK this sensor for 16" not this machine
                • fraig
                  • Nov 2014
                  • 36
                  • cairo
                  OK how ? what the points i will check ?
                  • fraig
                    • Nov 2014
                    • 36
                    • cairo
                    Help please
                    • alfredodinolfo
                      MacBook Pro 2019 (A1990)
                      by alfredodinolfo
                      mb code:820-01827-A;
                      sn:C02Z349ALVDR;
                      i9 32GB Ram 1TB
                      Hi, I found short on one of 6 black nand (total 1TB).
                      i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
                      I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
                      macbook with A2141 configuration run on recovery but don't complete it.​
                      anyone can help me?
                      05-26-2025, 09:27 AM
                    • robka
                      MacBook Pro 2018 - A1990 Dead - not charging - only 5V
                      by robka
                      my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
                      I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
                      The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
                      After that the Macbook was dead. It isn't charging anymore.
                      The USB-C Port where the charger was plugged is burned. Also The Cable and the...
                      03-02-2024, 02:58 PM
                    • DATATECH85
                      Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A
                      by DATATECH85
                      I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
                      The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
                      I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
                      However, I can't work out exactly why I don't have the PPBUS_G3H rail.
                      Here are the values...
                      07-24-2024, 06:34 AM
                    • falcontech
                      Macbook Pro a1990 activation locked
                      by falcontech
                      I received a 2018 MacBook Pro A1990 for repair, and the motherboard was replaced, presumably purchased on AliExpress. The motherboard's activation is blocked because the previous owner didn't delete it. Does anyone have a solution to this problem? I called Apple, and as expected, they asked me to activate the process with proof of purchase for the original computer, which I find very difficult, so the proof of purchase from AliExpress will be of little use. Any suggestions? Thanks.
                      09-29-2025, 06:57 AM
                    • Cameron Kajohn
                      A1990 MacBook no power help
                      by Cameron Kajohn
                      I have a a1990 2018 15 inch MacBook Pro that will not power on.
                      I have replaced the pch bga chip because it was heating up under my thermal camera.
                      I have replaced the battery, and replaced the small ic between the gpu and cpu as it had a direct short to ground.
                      the MacBook now pulls 20v 2.4amps the trackpad clicks but it does not ever attempt to power on not even fan spin. After PCH replacement I was able to get it in dfu mode 1 time and restore bridge OS, but now the MacBook will no longer go into DFU mode.
                      I have also noticed L7030 gets extremely hot yet...
                      01-24-2024, 12:00 AM
