1633 CM -4 94V - 0 E162264
  • clyde1210
    • May 2024
    • allemagne
    someone have schematic for asus R540L :
    motherboard 1633 CM -4 94V - 0 E162264
    Thanks a lot
  • clyde1210
    • May 2024
    • allemagne
    and if you have the boardview ....
    • AL._.EX
      • Dec 2022
      • 863
      • Belarus
      https://www.badcaps.net/forum/troubl...540l-schematic
      • clyde1210
        • May 2024
        • allemagne
        Thanks you very much
        • glovecaps
          by glovecaps
          11-25-2024, 04:23 PM
        • dhenion
          Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
          by dhenion
          I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
          The original board was:
          ASUS X510UNR REV 3.0 A
          The replacement board is:
          ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
          It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
          01-30-2024, 01:45 PM
          ASUS P5GC-MX motherboard recap
          by momaka
          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
          So here is what the motherboard looked like with its original caps:
          CPU VRM area up close…...
          01-27-2021, 11:59 PM
        • MakNCheese
          ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
          by MakNCheese
          I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
          Symptoms:
          • Severe lag across the system, including BIOS navigation.
          • Slow boot times and unresponsive performance in Windows.
          • Battery charges very slowly (e.g., ~5% in 2–3 hours).
          • No error messages or BSODs, just extreme sluggishness.
          What I've Tried:
          • Replaced
          06-04-2025, 12:48 AM
        • Pedro Ramírez
          BIOS on an Asus Prime H310M-E R2 motherboard
          by Pedro Ramírez
          Hi friends, I need help with the BIOS on an Asus Prime H310M motherboard - E R2, no video when turned on. I've attached the original backup....
          07-29-2025, 04:18 PM
