MS-16351 scehmatic
  • amirbassim
    • Jun 2012
    • 22
    • morocco
    MS-16351 scehmatic
    Hello, friends!
    can you help me with a MS-16351 VER.0B schematic
    the notebook won't start
    may be the PQ28, PQ30 mosfets are the cause?
    thanks!
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: MS-16351 scehmatic
    here it is
    hope it helps
    Im Back... sort of...
    • TechladUK
      • Feb 2016
      • uk
      Thanks for the file but it seems to be password locked !!
      does anyone know the password plz - or am I missing something??
      • LP_tekh
        • Oct 2015
        • 95
        • Laos
        You can open it using Acrobat Reader DC
        • bicalov
          • Nov 2014
          • 294
          • Netherlands
          Without password
          • BlackScreen_22
            Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
            by BlackScreen_22
            Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
            Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
            I had no problems connecting mosfets and capacitors,...
            08-27-2024, 12:46 PM
          • kotel studios
            Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
            by kotel studios
            Finally got time to fix this board up.
            At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
            Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
            04-22-2025, 05:08 AM
          • flerre
            Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
            by flerre
            Hi!
            Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
            No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
            So, could I safely assume all of these 3 mosfets are...
            03-13-2022, 12:14 PM
          • DrDos
            kenwood kr-6030 Mosfets?????
            by DrDos
            Hello everyone, I have decided to try and replace the mosfets in my power amp (the one with relay and left and right sides) on my kenwood kr-6030. I'm trying to get the A side of my speakers working. I have replaced all the caps in the power board and I thought why not change the mosfets. They seem to be working since I have great music coming out of the B side speakers and since I am not an electronic guru (but I am learning) I don't want to make any mistakes. The mosfets I have are listed A913 so I guess 2sa913 and 2sc1913. Can't really find those in mouser or digikey at least with the info...
            09-20-2025, 04:42 PM
          • NanoTesting
            Lenovo Ideapad 15IIL05, turns on and off with charger BUT works by injecting 20v after main mosfets
            by NanoTesting
            I got a 15-IIL05 that failed to turn on BUT IT DID TRY TO TURN ON and then turned off after 30+- seconds, i disassembled it and found a screw loose inside the case.
            With charger it turns on, fan spins but gives no image.
            Tested main mosfets no short, tested 3.3v,5v,DRAM, CPU etc and they were present.
            Reflashed BIOS, same problem.
            Replaced both main mosfets.
            Checked main mosfets again and i noticed that they closed once the laptop shut down, so i decided to bypass them and used a bench PSU to check how much power the laptop was drawing while trying to turn on, 20v@3A,...
            10-30-2024, 10:48 PM
