Anyone Have experience/Schematic w/ Acer Aspire 5532 Motherboard?
  • Paul678
    • Nov 2011
    • 402
    Re: Anyone Have experience/Schematic w/ Acer Aspire 5532 Motherboard?
    Originally posted by budm
    So on page 38 of the service manual where the ALWAYS ON 3.3V and 5V which are generated by the TWO SMPS you are not getting B+ at jumper PJ17?
    You also do not have VIN on page 38 from the DC input jack PJP1?
    Page 40: B+ comes from MOSFET switches PQ7, PQ8 which are turn on (PIN 4 ACDRV will go low when ACDET sees the VIN from AC adapter) when the ACDET PIN 5 of PU4 Power control IC sees VIN.
    Shit, Budm, can't you tell I'm trying to toss this motherboard
    into the junk parts bin???!!
    Ok, I'm NOT getting the VIN, +19V on the upper lead of resistors PR45
    and PR51, which are the voltage dividers for ACDET and OVPSET,
    so obviously ACDRV stays high, so I don't get B+.
    Problem is, these traces go into vias which disappear into the
    board (4 layers?), so who knows where the open may be.
    Damn, I just don't have the equipment to do this right! I need a good
    stereo microscope, and a sexy (but damn good) re-work
    assembler!
    Am I missing some obvious ribbon or cable somewhere? I'm
    pretty much testing it as I photographed it, with the ON/OFF
    power board attached. I just find it hard to believe that higher
    impedance voltage dividers would burn out an internal trace.
      The copper traces will have to be big enough to handle 3~4Amps, if they use Vias to handle that much current, then it is not good ideas unless to do mutiple VIAS. One thing that bugs me too is that I do not see the fuse at the DC input or at the batteries input at all. I wonder if PL1 inductor on page 38 from the DC input jack is open. Something like this bug me too, since we have the diagram and stiil we cannot see where we lost that 19V.
      • Paul678
        • Nov 2011
        • 402
        Well, even if we assume the input impedances to the chip are
        very low, with 340K resistors, it will only be about 56uA of
        current, so one via should be sufficient.
        The PL1 inductor works fine. The +19V is on both sides.
        The original Autocad gerber PCB trace files would be nice to
        have........
          But that same trace is connected to the PQ7 (pin 5~8) which supplies high current for B+. VIN current flows through tWO MOSFET's (PQ7, PQ8) so pin 2 of PR45 is connected to the VIN and PQ7.
          • Paul678
            • Nov 2011
            • 402
            I agree that the main Vin trace must be able to handle
            large currents.
            But ACDET only needs to sample the voltage with a high
            impedance voltage divider, so a skinny trace and a single
            via should be ok, which is what is on the board.
            Wish I could x-ray where those vias are going to......
              I think I misunderstood the reply, you are not getting ACDET at the pin of the IC and you are trying to find out why and where it disappears. At least you are getting close tegtting it working, may be you can do the new resistor network and jump the points instead.
              • Paul678
                • Nov 2011
                • 402
                #27
                Ok, I jumpered the Vin +19V to both voltage dividers,
                and I got the expected +2.7V on both pins, and B+
                was at jumper PJ17!
                But only for a few minutes, then for some reason
                Pin 4 ACDRV went high again, even though the
                correct voltages were at ACDET and OVPSET.
                I'm going to bed.......
                • nucleus
                  • May 2012
                  • 64
                  • Montenegro
                  #28
                  Originally posted by Paul678
                  You are incorrect.
                  It turns out there is no B+ anywhere on this board, so this chip was
                  NOT the problem.
                  There's a good reason I don't trust people who say they
                  are 100% sure they know the problem.....
                  Nevertheless, thanks to Nucleus for the excellent schematic!
                  Do you really live in this tiny little town?
                  http://en.wikipedia.org/wiki/Bijelo_Polje
                  I am glad I could help, and yes you are right I live in that small town. But my country is also very tiny so town isn't so small compared to country
                  use multimeter for resistance, or diode chek to find bad traces if any. look in schematics where it starts and where it ends, put probes on that points and test it. it is about 5 traces that could be bad so not much work to clear this suspicion
                  • techboyBG
                    • Aug 2012
                    #29
                    It`s old thread, but if anyone (like me) looks for schematic for Acer Aspire 5532. This is the http://laptop-motherboard-schematic....5332-5732.html link
                    If your PQ35 MosFET for NortBridge/Graphic burns everytime, you should check Pu12. Mine was gone. After replacement, it`s alive.
                    Regards.
                    • j.leeds09
                      • Mar 2013
                      Hey guys, I have the same problem as above, can anybody tell me how to test the PU12 FET?
                      • trebo
                        • 514
                        • Wales, UK
                        #31
                        What is PU12, you say it is a fet, are you sure about that, give us the numbers etc off it
                          ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-12-2024, 03:28 PM
                          ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-12-2024, 02:30 PM
                          ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                          ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                          ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
