Need help.LENOVO T480S BIOS Problem!
  • shiyab
    • Sep 2023
    • 1592
    • india
    Originally posted by jackx
    hello i need fix bios no data
    t840s 20l8-scl0y
    sn 177N2M
    snid wrong
    • meta99
      • Sep 2021
      • 27
      • Vietnam
      Hello
      My Thinkpad T480s POST very slow. Here is bios dump.
      S/N: PC112LYE
      Type: 20L8-S2YH00
      Please help!
      • hoaca388
        Badcaps
        • Jan 2022
        • 12269
        Originally posted by meta99
        Hello
        S/N: PC112LYE
        Type: 20L8-S2YH00
        Please help!
        T480s Laptop (ThinkPad) - Type 20L8
        โ€‹
        โ†ต
        โ€‹https://www.badcaps.net/donate
        • Migueltv61
          • Jan 2025
          • M
          Hello, I need help with my BIOS. I tried using autopatch, but after that, it no longer turned on. I need another good BIOS. For my T480s, S/N PC-15QBT3 TYPE 20L8-SF1000. Please help.
            • 21679
            post the original bios backup.
            • CountDImi
              • Aug 2025
              • 4
              • Estonia
              #26
              Hello. Having Issues with my Bios. Black screen. Keyboard lights up nothing else. Tried to replace Bios chip from other same model computer did not help.
              T480S 20L8
                • 21679
                T480S 20L8
                Type the laptop serial number, full name and model, motherboard model, etc.
                read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                • CountDImi
                  • Aug 2025
                  • 4
                  • Estonia
                  #28
                  Here
                  • Markus1741
                    • Sep 2020
                    • 922
                    • N/A
                    #29
                    Here
                    Hello you can try this new file ma be it helps ....
                    • CountDImi
                      • Aug 2025
                      • 4
                      • Estonia
                      #30
                      Hello after swapping BIOS chip between 2 same model laptops second working one stopped booting.
                      TYPE 20L8-S8SF00 S/NPC-1339ZJ 19/03 Bios and EC.bin attached.
                      Thank you.
                      • CountDImi
                        • Aug 2025
                        • 4
                        • Estonia
                        #31
                        Sorry it did not help fixing the issue.
                        • xugopef@mailapps.online
                          • Oct 2025
                          • 4
                          • Italy
                          #32
                          Hello, I'm having trouble booting my T480s after a BIOS flash. I'm using a Pi Pico 2040 (serprog) with flashprog.
                          I dumped the stock BIOS three times, the checksum was the same. I added the usual patches, and how the laptop won't turn on: attempting to power on for a second (display powers up, keyboard lights up), power LED blinking three times, fan spins every few seconds.
                          Reflashing the stock firmware didn't help. I tried reflashing after using me_cleaner on the stock image, still nothing. Tried some BIOS images from around this forum, nothing. I even tried Coreboot, nothing.
                          The diodes and SMD components close to the BIOS chip seem to be okay, I checked with a multimeter.
                          The model code is S0L8-S6RF00, serial number PC-12ZR7C, i5-8350U
                          I'm attaching the stock BIOS and the modded one, thank you.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12269
                            #33
                            Try # 23
                            โ†ต
                              • Oct 2025
                              • 4
                              • Italy
                              #34
                              Originally posted by hoaca388
                              Try # 23
                              Still bricked with no changes ๐Ÿ˜•
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12269
                                #35
                                Vแบซn bแป‹ lแป—i mร  khรดng cรณ thay ฤ‘แป•i gรฌ ๐Ÿ˜•
                                So the error may not be due to bios.
                                โ†ต
                                • Markus1741
                                  • Sep 2020
                                  • 922
                                  • N/A
                                  #36
                                  Hello you can try this new files good luck ....
                                    • Oct 2025
                                    • 4
                                    • Italy
                                    #37
                                    Sadly nothing changed with any of the two files, thank you anyway...
                                    At this point I'm considering a hardware issue too. Are you aware of any hardware debug interfaces (JTAG, UART, etc) I can use to get an idea?
                                      • Oct 2025
                                      • 4
                                      • Italy
                                      #38
                                      Update: it's indeed a hardware issue, the clip knocked off the two 33 ohm resistors on the bottom!
                                      I got it to boot with some bodge wires, not ideal but better than dead. I might get a new motherboard later since I ripped some pads and I don't trust the wire, and recycle this one as a server (I wanted one for Home Assistant Voice anyway).
                                      Thanks a lot for all the help!
                                      • lucaszmn
                                        by lucaszmn
                                        Problem:
                                        Initial Findings:
                                        • I concluded that the
                                        08-12-2025, 03:01 PM
                                      • AquaMan Ua
                                        by AquaMan Ua
                                        05-17-2025, 09:40 AM
                                      • traxformania
                                        TONGFANG "GM7TG7P" Bios Password Problem?
                                        by traxformania
                                        I tried :
                                        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                        11-15-2023, 07:32 AM
                                      • macabook
                                        ๐Ÿ› ๏ธ MSI GP75 Leopard MS-17E71 โ€“ No Display, Deep BIOS/EC Troubleshooting
                                        by macabook
                                        Iโ€™m currently working on a dead MSI GP75 Leopard (MS-17E71) motherboard (i7 CPU, NVIDIA GPU) with a no display/no backlight issue initially. After extensive investigation, Iโ€™m at a critical stage involving EC firmware, BIOS/ME region interaction, and possible deep corruption. I'm seeking advanced insight from anyone with experience in EC/BIOS sync issues or PCH-level behavior. Hereโ€™s a full breakdown:
                                        ๐Ÿงฉ Initial Issue
                                        07-24-2025, 02:17 PM
                                      • trouble55
                                        NEC VersaPro PC-VRT42FBFR22B BIOS problem
                                        by trouble55
                                        Hi All,
                                        [Mother board model]
                                        V-VE212(U3E1)
                                        [Serial number]
                                        24000135PA
                                        [BIOS chip model]
                                        Macronix MX77L12850F
                                        I am having some problems with the BIOS of my Versapro PC-VRT42FBFR22B.
                                        I extracted the BIOS file (versapro001.bin 16MB) from PC-VRT42FBFR22B ROM (MX77L12850F) using CH341A and NeoProgrammer V2.2.0.10, but I don't know how to remove the BIOS password, so I can't open the BIOS even if I boot with F2.
                                        I also downloaded the BIOS update package (933A0400.zip) for PC-VRT42FBFR22B from the official...
                                        09-19-2024, 01:24 AM
