Lenovo ThinkPad P15v bios needed
  • salawayon
    • Nov 2012
    • 578
    • philippines
    info:
    GT5A0/GP5A0
    NM-C641
    REV: 2.0
    no display on this one. i attached my backup. thanks
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: Lenovo ThinkPad P15v bios needed
    Originally posted by salawayon
    info:
    GT5A0/GP5A0
    NM-C641
    REV: 2.0
    serial number???
    • salawayon
      • Nov 2012
      • 578
      • philippines
      SN: PF-39WAVT
      lenovo thinkpad P15v Gen 1
      • salawayon
        • Nov 2012
        • 578
        • philippines
        anyone could share a working bios?
        thanks
        • hardware1
          • Sep 2021
          • 2949
          • N/A
          info:
          GT5A0/GP5A0
          NM-C641
          REV: 2.0
          This isn't your Backup file.
          all donations are welcome,
          • salawayon
            • Nov 2012
            • 578
            • philippines
            sorry. the bios chip was untouched and that's what i got after reading the chip...
            • volinakis
              • Jan 2021
              • 2877
              • N/A
              I have a P15v that, after bios update from windows update, it started overheating and CPU is throttling. I noticed that windows update made a EC update to v1.14 (N30HT34W) and this version doesn't exist in Lenovo official update, last EC version being v1.16 (N30HT33W). I was able to downgrade bios but it doesn't also downgrade EC version. So, my question is if lenovo bios upgrade program can be altered to force a EC downgrade (something like alter ini file to skip verifying EC version but I can't find ini file). EC is NPCX897 and I can't modify it (I have a RT809H).
              S/N: PF-2WJHT3, model 20TQ , attached bios dump, please verify also bios dump maybe something is also wrong in it.
              Thank you!
                • 22293
                Thank you!
                The last EC version is N30HT34W
                https://download.lenovo.com/pccbbs/mobiles/n30uj17w.txt
                Code:
                Package   (ID)   UEFI BIOS (BIOS ID) ECP (ECP ID)   Rev. Issue Date
                1.34   (N30UJ17W) 1.34 (N30ET51W)   1.17 (N30HT34W)  02  2003/08/04
                D1702 looks a little bit wonky
                • volinakis
                  • Jan 2021
                  • 2877
                  • N/A
                  Code:
                  that's funny, if you click on "details" and scroll down you'll find this: (see photos) . But it's good to know that v1.17 was released in 2003
                  also, extracting files from latest bios update i found for EC "N30HT33W" which coresponds with v1.16
                    • 22293
                    2003 i didn`t notice that
                    • hardware1
                      • Sep 2021
                      • 2949
                      • N/A
                      Thank you!
                      If you want to try a New BIOS, you can try the attached one.
                      • volinakis
                        • Jan 2021
                        • 2877
                        • N/A
                        thank you very much, I will try tomorrow and provide feedback.
                        • volinakis
                          • Jan 2021
                          • 2877
                          • N/A
                          Apologise for late response, client took laptop and went in vacation, bring it back 2 days ago. Bios you provided doesn't work at all, laptop doesn't start, when I press power on button nothing happens. But thanks a lot for your time!
                          I think in my case is not a bios problem, when I run stability test under Aida64 only powered on battery CPU doesn't throttling and temperatures are ok. I discovered this by mistake, I thought AC Adapter was plugged in into 220V socket but it wasn't!
                          Thank you ALL for your time and help!
                          • snake35
                            • Jan 2024
                            • 5
                            • France
                            Hi, I have a Lenovo P15v Gen1 and I would like unlock the bios. I only see one flash W25Q256.
                            type: 20TQ-004AFR
                            SN: PF-2G995L
                            can someone unlock bios?
                            Thanks a lot
                            • snake35
                              • Jan 2024
                              • 5
                              • France
                              anyone to help me?
                              • layad
                                • Nov 2011
                                • 249
                                hi there
                                have here p15v thinkpad lenovo
                                serial number pf-309c95 ,
                                goes off after sometime , then it turns on again with self healing process , and so on ,
                                changed the bios chip with new one after transfering the orginal dump .. still the same, tried to rebuild the dump file but it ends up with wrong size file
                                i dont know what im missing here
                                  SMDFlea commented
                                  Editing a comment
                                  Thread merged.Please use the forum search to find related threads where you can post your request.You do not need to start a new thread every time
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12441
                                Originally posted by layad
                                hi there
                                Laptop P15v Gen 1 (ThinkPad) - Loại 20TQ
                                • layad
                                  • Nov 2011
                                  • 249
                                  worked like charm thank you
                                    Lenovo ThinkPad ThinkPad P15v Gen 2 Notebook P Specification for Upgrade or Repair
                                    This specification for the Lenovo ThinkPad ThinkPad P15v Gen 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad P15v Gen 2 boardview and ThinkPad P15v Gen 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    09-07-2024, 04:10 AM
                                  • lucaszmn
                                    by lucaszmn
                                    Problem:
                                    Initial Findings:
                                    • I concluded that the
                                    08-12-2025, 03:01 PM
                                  • to5it0
                                    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                    by to5it0
                                    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                    I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                    This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                    I have opened the laptop and identified the main BIOS chip...
                                    10-24-2025, 01:35 AM
                                  • trepachka
                                    Lenovo Thinkpad P15v Gen 2 BIOS needed
                                    by trepachka
                                    Hello, I have this Lenovo Thinkpad P15v Gen 2. It powers, the keyboard lights up, the fans start spinning, the CPU heats up normally. However, it is not posting and I suspect the bios is corrupted.
                                    Can someone provide a clean bios?
                                    The information on the computer is below:
                                    Serial# PF2R5YZM
                                    Type# 21A9-004AUS
                                    I found 2 identical BIOS chips on the motherboard, same model. One is marked U2001 and the other one is marked U4402. Both chips are 25Q256JVEQ
                                    I am providing BIOS dump as attachment.
                                    Thank you for your tim...
                                    01-28-2024, 01:38 AM
                                    Lenovo ThinkPad P15v Mobile workstation P Specification for Upgrade or Repair
                                    This specification for the Lenovo ThinkPad P15v Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P15v boardview and P15v schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                    09-07-2024, 06:40 AM
