Asus n751jk -help- I need bios dump with clear me
  • ninjanody
    • Feb 2020
    • 19
    • Greece
    I need a bios dump for n751jk rv.2. The laptop is no responding to power button, but the led for power and charging are light up.
  • ninjanody
    • Feb 2020
    • 19
    • Greece
    Re: Asus n751jk -help- I need bios dump with clear me
    I flashed the bios from this thread (N751JKF1205.zip from cacla) but now it don't even respond to power jack inserted (no power led, charging led)
    • peste
      • Dec 2016
      • 12667
      • ROMANIA
      post the original bios even if it is corrupted
      • cacla
        • Apr 2015
        • 442
        Hi there mate pls give me sn form your unit and i will give you the right bios file
        • ninjanody
          • Feb 2020
          • 19
          • Greece
          sn: F1N0BC004902026
          N751JK-T7042H
          • ninjanody
            • Feb 2020
            • 19
            • Greece
            here
            • cacla
              • Apr 2015
              • 442
              This is F1 bios try it
              • ninjanody
                • Feb 2020
                • 19
                • Greece
                After flashing the bios, when i plug the power jack, the fan starts spinning for a second and stops. It does that several times and then the fan spins at full speed for 2-3 minutes and reboots.
                Still no beep, no post, no leds on external keyboard. The onboard leds are on, but the power led is dim. Probably there is a short somewhere.
                • lapfix
                  • Mar 2020
                  • 2715
                  • my workshop
                  Can you post a clear picture of this ticket
                  • ninjanody
                    • Feb 2020
                    • 19
                    • Greece
                    Here.
                    And video of the power on. Also the power led is not as bright as the others, if you saw it no the video.
                    • razor_amd
                      by razor_amd
                      12-15-2020, 07:07 PM
                    • DynaxSC
                      by DynaxSC
                      06-14-2024, 03:49 PM
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • Anchar777
                      ASUS P1412CE need BIOS DUMP
                      by Anchar777
                      Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                      06-26-2025, 03:39 AM
                    • kcp0085
                      Request BIOS dump for ASUS FA617NS-A16.R77600
                      by kcp0085
                      Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
                      I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
                      Specs:
                      - ASUS TUF FA617NS-A16
                      - CPU: AMD Ryzen 7
                      - BIOS chip: Winbond W25Q16JVSIQ (2MB)
                      If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
                      Thanks in advance!​
                      05-02-2025, 12:52 AM
