Need Lenovo Legion 5-15IMH05H NM-c911 bios Clean dump
  • Xwalt
    • Apr 2023
    • 7
    • UAE
    Legion 5 15IMH05H Type 81Y6 BIOS HELP
    Lenovo Legion 5 15IMH05H
    S/N: PF1BTUHM
    MTM:81Y600DCUS
    Laptop crashed in a bios update, now boots to a black screen, I flashed a new bios and it is still the same albeit it doesn't crash after a few seconds now.
    I dumped the original BIOS file with my CH341A programmer.
    Would appreciate any help
    • hardware1
      • Sep 2021
      • 2948
      • N/A
      Re: Legion 5 15IMH05H Type 81Y6 BIOS HELP
      S/N: PF1BTUHM
      MTM:81Y600DCUS
      Here's your New BIOS, it's a Virgin BIOS from Lenovo with your DMI and Windows Key.
      all donations are welcome,
      • Xwalt
        • Apr 2023
        • 7
        • UAE
        Thank you for replying.
        I tried the BIOS and the issue still persists, it's a black screen and does not boot into anything. The fans do ramp up now on full speed and then it crashes.
        FYI this is my bios chip and the software I am using (Asprogrammer does not have 25l12872f, only 25l12873f). I unplug the CMOS battery and main battery before flashing, I cleared it before writing and also verified after. Once I boot the bios is different from the virgin one but I am guessing that is what is supposed to happen.
        I guess it's also worth mentioning that I suspect the GPU on my laptop has an issue which is why I updated the BIOS in the first place. Is it possible that the BIOS is booting into discrete graphics mode only? Is there a way to change that without a screen? (I tried external monitors, but no dice)
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          Try NeoProgrammer V2.2.0.10 , it does support 25l12872f
          https://www.badcaps.net/forum/showpo...postcount=2374
          Also try with older version of the bios, look at the fist page of the thread.
          Become a Badcaps supporter
          Thanks to all supporters.
          • Xwalt
            • Apr 2023
            • 7
            • UAE
            I tried the programmer and the bios hardware1 made and I managed to get it to the original issue where disabling hybrid mode would cause the black screen issue. I did some stupid maneuvers to disable it within windows but now I can finally see the screen!
            Thanks!
            Now to fix the 2060 vbios
            • Xwalt
              • Apr 2023
              • 7
              • UAE
              #26
              Hi, I noticed the S/N on the BIOS you provided does not match the S/N on the bottom of the laptop. Did you accidentally post the wrong file or was the BIOS modified before?
              • hardware1
                • Sep 2021
                • 2948
                • N/A
                #27
                No, I made it for you. Perhaps someone changed the Laptop Bottom Cover, or your BIOS file wasn't the Original Backup.
                • cyngo
                  • Jun 2015
                  • 219
                  • Indonesia
                  #28
                  Need Clean ME Legion 5 15IMH05H Bios
                  The problem is when enter the OS, always bluescreen & freeze.
                  thanks in advance
                    • 21853
                    Re: Need Clean ME Legion 5 15IMH05H Bios
                    Originally posted by cyngo
                    The problem is when enter the OS, always bluescreen & freeze.thanks in advance
                    You MUST:
                    • peste
                      • 13573
                      • ROMANIA
                      #30
                      thanks in advance
                      did you try post #2???
                      • cyngo
                        • Jun 2015
                        • 219
                        • Indonesia
                        #31
                        Yes, I have tried it, but the problem remains the same.
                        • cyngo
                          • Jun 2015
                          • 219
                          • Indonesia
                          #32
                          Originally posted by SMDFlea
                          You MUST:
                          Thank you for the information
                          • peste
                            • 13573
                            • ROMANIA
                            #33
                            if you wrote the bios without errors, then the laptop has another problem
                            • cyngo
                              • Jun 2015
                              • 219
                              • Indonesia
                              #34
                              Re: Need LenovoLegion 5-15IMH05H NM-c911 bios Clean dump
                              yes, maybe problem is something other than bios. thank you
                              • Ado02
                                • Jul 2021
                                • 100
                                #35
                                bios extracted from Lenovo website update for Legion 5-15IMH05, Legion 5-15IMH05H, Legion 5P-15IMH05, Legion 5P-15IMH05H, Legion 5-17IMH05, Legion 5-17IMH05H
                                DMI 532000 - 533FFF
                                Hi, will this bios work instead of the attached bios? I believe the version is EFCN59WW.
                                I have already tried it, but the screen remains black. So, I just wanted to confirm that is should work. If not can someone help me with the correct bios?
                                SN: PF1ANGW6
                                  • 21853
                                  Post your original bios dump and serial number and we`ll see. https://www.badcaps.net/forum/showthread.php?t=103570
                                  • Ado02
                                    • Jul 2021
                                    • 100
                                    #37
                                    Sorry, the original attachment failed. I just noticed it. It's now added.
                                    • Ado02
                                      • Jul 2021
                                      • 100
                                      #38
                                      Can anyone help?
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12322
                                        #39
                                        Can anyone help?
                                        Legion 5-17IMH05H (Lenovo) - Type 81Y8
                                        • Ado02
                                          • Jul 2021
                                          • 100
                                          #40
                                          Thank you for being so helpful. Unfortunately, the problem is still there. I compared your BIOS file and the backup BIOS, and they are very different. If the original BIOS was corrupted, this would make sense. But why is the problem still happening? Am I missing something, or could it be a hardware issue?
                                          If the screen is the problem would I still be able to get an HDMI output on this model without the laptop booting into Windows?
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • haitham sharabati
                                            by haitham sharabati
                                            Hello engineers 😀,
                                            🔧 Device Info:
                                            - Model: HP 15-da2007ne
                                            - Product Number: 8XF55EA#ABV
                                            - Serial Number: CND0338P0D
                                            - CPU: Intel Celeron N4000
                                            💀 Problem:😅
                                            08-07-2025, 04:54 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
