asus X570DD rev 2.0 bios
  • manh trung
    • Aug 2020
    • 53
    • vietnam
    I need bios dump. thanks you
    frank martin
    • 21472
    Re: asus X570DD rev 2.0 bios
    post the laptop serial number ,and pictures of any long white/green barcode stickers and/or square white QR codes on the motherboard.Attach your images to badcaps,not links to external image host.
    • manh trung
      • Aug 2020
      • 53
      • vietnam
      this is the root dump. I would be happy if I could clean the bios
      frank martin
      • hoaca388
        Badcaps
        • Jan 2022
        • 12132
        See #2.
        • hardware1
          • Sep 2021
          • 2943
          • N/A
          Model: M570
          Board: X570DD
          Serial Number: KA41NBCX001XU2MB
          all donations are welcome,
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • kodox
            Asus ExpertBook B1400CB Bios Dump Needed
            by kodox
            need original bios dump, original bios has flashed by other technician before me.
            attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
            unit info:
            Model: Asus ExpertBook B1400CBA-0711A1235U
            S/N: R6NXNZ006657238
            CN: 7F6F
            Mainboard Code: B1500CBA R2.1...
            08-16-2025, 12:20 PM
