asus X570DD rev 2.0 bios
  • manh trung
    • Aug 2020
    • 53
    • vietnam
    I need bios dump. thanks you
    frank martin
    • 22290
    Re: asus X570DD rev 2.0 bios
    post the laptop serial number ,and pictures of any long white/green barcode stickers and/or square white QR codes on the motherboard.Attach your images to badcaps,not links to external image host.
    • manh trung
      • Aug 2020
      • 53
      • vietnam
      this is the root dump. I would be happy if I could clean the bios
      frank martin
      • hoaca388
        Badcaps
        • Jan 2022
        • 12441
        See #2.
        • hardware1
          • Sep 2021
          • 2949
          • N/A
          Model: M570
          Board: X570DD
          Serial Number: KA41NBCX001XU2MB
          all donations are welcome,
          • mkdj
            by mkdj
            Dear all,
            10-19-2025, 04:41 AM
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • pirati
            by pirati
            10-27-2025, 04:20 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
