ASUS UX431FAC/FLC REV 2.0 Bios need
  • Simon16
    • Sep 2017
    • 102
    • España
    Please, I need bios bin file for Asus UX431F
    The motherboard is: UX431FAC/FLC REV 2.0
    The bios chip is: XM25QH128AHIG
    Attached original bin file and photo of the motherboard with its reference.
    Thanks in avance
  • cacla
    • Apr 2015
    • 444
    Re: ASUS UX431FAC/FLC REV 2.0 Bios need
    Pls sn form the unit
    • Simon16
      • Sep 2017
      • 102
      • España
      Thank you for your interest in helping me.
      Sorry, I don't know the serial number.
      The bottom case sticker is rubbed off. It can not be read.
      • ddhlawi
        • Feb 2017
        • 169
        • algerian
        take new bios whithe officiel site
          • 21936
          Post pictures of all long white/green barcode stickers, or square white QR codes on the motherboard
          • Simon16
            • Sep 2017
            • 102
            • España
            Again, thank you both for your help.
            I haven't tried the file provided by ddhlawi yet
            Attached photo with motherboard sticker
            • cacla
              • Apr 2015
              • 444
              Try this one
              • Simon16
                • Sep 2017
                • 102
                • España
                I have tried the files (cacla and ddhlawi) but it still doesn't work.
                He does the same with both. The third or fourth press of the power button turns on the button led and the ignition, but does nothing else. The fan doesn't even work, although I do notice the CPU and GPU getting a bit hot.
                I don't know whether to try some other BIN file or replace the IT8987E BXS multicontroller.
                Any suggestions?
                • Simon16
                  • Sep 2017
                  • 102
                  • España
                  I decided that I was going to change the IT8987E BXS but I didn't get to do it.
                  The reason is that before changing it, I reprogrammed the original bios and pressed the ignition in case "magically" the laptop worked and it really works!
                  In case someone needs it, the file I put in the first post works.
                  Does anyone know what could have happened so that it now works with its original bios? I tried, without success, with the two that cacla and ddhlawi attached in this thread and then put the original one back.
                  What could have changed?
                  • NuclearJoyride
                    • Nov 2022
                    • 8
                    • Belarus
                    @Simon16, you just flashed the original bios from the Asus website, pressed the power button and it worked?
                    • DK David
                      • Feb 2023
                      • Ghana
                      ASUS UX431FAC/FLC REV 2.0 Bios need ASP
                      • peste
                        • Dec 2016
                        • 13630
                        • ROMANIA
                        always, when you make a bios request, also post the original bios of the laptop, even if it is corrupted..
                        • Akhiru Khoeruddin
                          • Nov 2022
                          • Indonesia
                          ineed bios ux431FAC/FLC rev 2.0 8mb
                            • 21936
                            Read posts 5,6 and 12.If you have UX431FLC on your white QR sticker flash the bios at post 7 but make a backup first.
                            • GadgetsFix
                              • Feb 2021
                              • 7
                              • United Kingdom
                              Can someone clear the BIOS please:
                              Asus UX431F
                              K4N0JX00L278173
                              60NB0MB0-MB2120​
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12332
                                Asus UX431F
                                K4N0JX00L278173
                                60NB0MB0-MB2120​
                                File's corrupted or wrong chip.
                                • razor_amd
                                  by razor_amd
                                  12-15-2020, 07:07 PM
                                • pirati
                                  by pirati
                                  10-27-2025, 04:20 PM
                                • grimacelord
                                  by grimacelord
                                  07-10-2025, 02:52 PM
                                • jbonavita
                                  by jbonavita
                                  Some issues
                                  Things I tried
                                  04-29-2025, 09:38 PM
                                • throwaway327
                                  by throwaway327
                                  Model No: RC72LA
                                  Serial No: SBNVKD001014459
                                  06-18-2025, 05:52 PM
