Dell G15 5511 (GDL58 LA-K455P)
 Dell G15 5511
 Service Tag: HTRX1Q3
 Laptop comes with no display issue
 tried so many bios from internet
 some are not turning on
 some are just logo showing and restart
 so i just tried change the BIOS REGION only in original file (Extracted from a internet file)
 display came without any delay no restarting
 But SSD is not detecting
 is there any solution for this
 Dell G15 5511 service tag HTRX1Q3Dell G15 5511
 is there any solution for this↵
 https://www.badcaps.net/donateComment
 hi
 help me rebuid my bios
 Dell G15 5511
 service tag-91TBYR3
 thanks
 Attached FilesComment
 Dell G15 5511
 Service Tag: 91TBYR3Attached Files↵
 DELL G15 5511
 ST; 4YPVHM3
 NO DISPLAY
 DELL G15 5511 SOME TIME NO POWER
 ANYONE CAN CLEAR MY ORIGINAL BIOS??
 M/B PART NO -GDL58 LA-K455P
 S/N - 2NB08K3
 OLD BIN ATACHEDAttached FilesComment
 try and feedbackComment
							Channel: BIOS Requests ONLY!
			by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...-
 04-23-2025, 04:30 PM
			by capoplaysHey everyone,
 I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
 The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
 When I check the BIOS using the F12 menu Flash...-
			by Akhlz001Hi,
 Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
			by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
- Loading...
