Hi all, I am working on this Hp 14-dq0017ca Board # DA0PABMB6E0 REV: E (S: No: 5CD016BF8T), Can anyone do a ME Region cleaning on this original BIOS. I have uploaded the original BIOS. I would really appreciate if someone can do it ASAP. Thanks in advance
ME Region Cleaning for Hp 14-dq****** DA0PABMB6E0 REV: E
Re: ME Region Cleaning for Hp 14-dq0017ca DA0PABMB6E0 REV: E
Rather than cleaning the ME firmware its much easier with this one to use a virgin bios and coy your DMI info to it.Cleaning the ME doesn`t always fix the bios if there is some other corruption,and if it isn`t working with a virgin bios (try older versions as well) then you can say for certain that the problem is somewhere else.If you learn how to extract and copy the DMI yourself you can have the job done in less than 2 minutes, give it a try at least and if you can`t do it or find it hard its no problem,just say so and someone will fix it for you.
Download and run the bios update exe from hp support, choose save to location. There are 4 different bios, only 2 of them are 8MB so ignore the others. Use a hexadecimal editor and do a tex search for 0864 ,as there`s 0864A and 0864D and you don`t know which one to choose. Yours is 0864D .
Copy the DMI using the following off-sets.
DMI 747000 - 7480FF
WK 76D000 (length 40)
.Last edited by SMDFlea; 11-09-2022, 11:50 PM. -
Thank you so much SMDFlea., Does this method work for all Hp BIOS or it's work from model to model? I did matched the BID number with the orginal Bin file so I knew that mine was 0864D. Because when I programmed the 0864D onto the chip, the notebook turned on, but in ON position the board was not taking any amps & only the LEDs were solid WHITE & no Activity. So let me understand once for all., I will copy the DMI 747000 - 7480FF (length 40) from the older BIOS & paste this to the newer one BIN file??? & what is this "WK 76D000" ??? SMDFlea. really appreciate your help.Comment
It works to extract all the latest bios update versions. If its an Insyde bios then the DMI can be copied,you just have to find out where the offsets are.Thank you so much SMDFlea., Does this method work for all Hp BIOS or it's work from model to model? I did matched the BID number with the orginal Bin file so I knew that mine was 0864D. Because when I programmed the 0864D onto the chip, the notebook turned on, but in ON position the board was not taking any amps & only the LEDs were solid WHITE & no Activity. So let me understand once for all., I will copy the DMI 747000 - 7480FF (length 40) from the older BIOS & paste this to the newer one BIN file??? & what is this "WK 76D000" ??? SMDFlea. really appreciate your help.
"WK 76D000" is the Windows Key, 76D000 is the start offset, i didn`t post the end offset but instead posted the file length (length 40) .
747000 - 7480FF is the DMI area ,the file length is much longer.The DMI area contains the serial number,model number and feature byte.Comment
I have replaced the processor on the HP 14 laptop, replaced the N4020 with an N4000, do I need to edit the bios? after completing the installation the laptop doesn't display, capslock led blinking fast 3X slow 5X and so on
hp 14-dq0002dx
SN# 5CD104BDL9
I am attaching the original bios fileAttached Filesif you find these attachements useful please consider making a small donation to the site
hi try not dmi addI have replaced the processor on the HP 14 laptop, replaced the N4020 with an N4000, do I need to edit the bios? after completing the installation the laptop doesn't display, capslock led blinking fast 3X slow 5X and so on
hp 14-dq0002dx
SN# 5CD104BDL9
Post the motherboard model number and revision.I have replaced the processor on the HP 14 laptop, replaced the N4020 with an N4000, do I need to edit the bios? after completing the installation the laptop doesn't display, capslock led blinking fast 3X slow 5X and so on
hp 14-dq0002dx
SN# 5CD104BDL9
by Destroyer-BrI’m working on a laptop in which I replaced the PCH, but I’m unable to clean or rebuild the Intel ME region using FIT.
When I load my dump into FIT, it only shows the Intel(R) ME Kernel section. The full ME region structure does not appear.
If I manually replace the ME region inside the decomp folder and try to build the image, FIT does generate an outimage.bin, but the file is corrupted.
After flashing it, the board does not power on — no signs of life.
I’ve identified that the issue happens because my original dump does not contain a complete or valid ME...-
Channel: BIOS Requests ONLY!
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
by loopsterHello guys,
could I please get some help cleaning the ME region of the attached Zbook 17 G1 bios dump (CH341a, neoprogrammer, chip-desoldered, dumped twice, identical checksum)?
Symptoms, delayed BIOS post (ca. 45 secs.) keyboard not working, touchpad not working, booting linux live, console says "Management engine not configured".
I tried following the ME firmware cleaning guide, but whatever Flash Image Tool version I try, I get the same error:
Error 10: Failed to open with processed commands.
Unable to open file: C:\Users\Elitebook...1 Photo-
by tom3kLaptop: Dell Precision 5540
MB: LA-H331P Rev: 1.0(A00)
Hi.
I am looking for a clean ME Region 12.0.95.2489 Corporate H CNP/CMP-H B, A
After extracting my BIOS in FIT the ME Region size is 7565 KB.
However the ME Region files I fouud online are 11688 KB in size.
Can someone help me find he correct clean ME Region?
Thanks!
...Code:╟─────────────────────────────┬───────────────╢ ║ Family │ CSE ME ║ ╟─────────────────────────────┼───────────────╢
by ASBI tried to clean ME region of HP 400 G2 ALL IN ONE PC but didn't succeed. Experts please help....
- Loading...
