[OFFER] Fix any ASUS BIOS for free. Post dumps and I'll try to help.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Title says it all. Been doing enough of these to know my way around them. Usual symptoms are no video or no power to CPU hence no video. As long as the dump isn't completely corrupted and there is an update to be found on Asus' website, I can fix it for you. File delivered will either be original ME so no issues, or clean ME with update ME to latest supported version.
    Awaiting requests. Free service so if you're in a hurry, look elsewhere.
    I've asked in several places, including here, before, and I got them done on my own before anyone else had time to help.
    A working TV? How boring!
  • Batto
    • Sep 2024
    • 5
    • France
    I have my Asus Vivobook Flip 14 that won't boot anymore, no POST, only fan spinning and black screen. Power light on but no disk activity light.
    Please find below the bios that fails, It is version 308.
    I also attached the official bios from ASUS (TP412FACAS.308).
    I have a CH341 programmer so i just need to get a working bios.
    Do you think you can try and solve my problem?
    Thanks in advance.
    • hoaca388
      Badcaps
      • Jan 2022
      • 12346
      Thanks in advance.
      Serial number ?
      • Batto
        • Sep 2024
        • 5
        • France
        Serial
        L6N0LP00Z02024B
        • danito
          • Jun 2016
          • 1105
          Serial
          L6N0LP00Z02024B
          try
          • Batto
            • Sep 2024
            • 5
            • France
            It didnt work.
            Could you try something else to make it boot, please?
            By the way, the 308 version of the bios may be what bricked my MB (forced update by windows update, failure after update). Can you consider using the 306 version of the firmware, see attached (i shouldn't have proposed the 308 in the first place, sorry).
            Gotta go to work but I hope you will find the solution.
            Thanks again for your time.
            • peste
              • 13661
              • ROMANIA
              It didnt work.
              post the S/N, the motherboard model, the full name and model of the laptop,etc.
              • Batto
                • Sep 2024
                • 5
                • France
                Thanks for trying to help.
                The Serial Number: L6N0LP00Z02024B
                MB: TP412FAC R2.0
                Laptop: tp412fa-bs71t-cb
                Hope you will figure out.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12346
                  MB: TP412FAC R2.0
                  Try
                  • Batto
                    • Sep 2024
                    • 5
                    • France
                    Unfortunately it did'nt work but still, I thank you for the effort.
                    ​I always do a SHA256 check after i flash the bios to verify that it has been correctly flashed so I'm sure the CH341A does the job well.
                    My guess is that the bios is corrupted but it may be the soldered RAM or the processor that are somewhat broken but i don't know how to check that.
                    Anyway, if you have others repaired bioses to propose, I'd be thankful.
                    Bye
                    • razor_amd
                      by razor_amd
                      12-15-2020, 07:07 PM
                    • pirati
                      by pirati
                      10-27-2025, 04:20 PM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • throwaway327
                      by throwaway327
                      Model No: RC72LA
                      Serial No: SBNVKD001014459
                      06-18-2025, 05:52 PM
                    • lrouw84
                      Asus vivobook s510ua bios changed to x510un
                      by lrouw84
                      Hi there,
                      I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                      I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                      01-28-2023, 01:31 PM
