DELL DV14 MLK DIS 112821-1 BIOS Pls
  • yuviuv46
    • Aug 2022
    • 11
    • India
    Need of bios file if anyone has please share it.Thanks
  • peste
    • 13924
    • ROMANIA
    Re: DELL DV14 MLK DIS 112821-1 BIOS Pls
    always when you make a bios request also post the original bios of the lapop even if it is corrupted..
    • yuviuv46
      • Aug 2022
      • 11
      • India
      Have uploaded the corrupted one.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12441
        Inspiron 3420
        Service Tag: 9FBDCV1
        • yuviuv46
          • Aug 2022
          • 11
          • India
          Thanks alot will try and post it.
          • yuviuv46
            • Aug 2022
            • 11
            • India
            Originally posted by hoaca388
            Inspiron 3420
            Works.Thanks alot
            • zenius
              by zenius
              12-08-2024, 06:13 AM
            • mikeybass
              by mikeybass
              04-23-2025, 04:30 PM
            • capoplays
              Help with BIOS update on Dell G15 5515 after chip replacement
              by capoplays
              Hey everyone,
              I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
              The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
              When I check the BIOS using the F12 menu Flash...
              10-24-2025, 06:53 AM
            • Akhlz001
              by Akhlz001
              09-20-2025, 07:15 PM
            • Sathsul
              Dell Latitude 5431 issues with dumping bios
              by Sathsul
              So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
              The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
              However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
              10-28-2025, 07:49 AM
