Dell Latitude 5430, LA-L591P Computrace setting unlock
  • PycLaH
    • Feb 2022
    • 28
    Dell Latitude 5430 ,LA-L591P can anyone check bios plz, and remove computrace
    Thx
    • PycLaH
      • Feb 2022
      • 28
      Symptoms:
      power button lights comes on, charging light comes on white(charger plugged in), no display , no fan spin. after a while i have few white blinks (charging light) 4 times , and power lights goes off.
      Please help - This is Dell Latitude 5430 Laptop . i5 16GB ram, STAG: FB1Z0T3
      + anyone can check my bios file dump and set it up to manufacture mode . no password in the dump.
      Thanks​
      • PycLaH
        • Feb 2022
        • 28
        Thank you for reply, need dump it. text you shortly
        Regards,
        Ruslan
        • PycLaH
          • Feb 2022
          • 28
          this is 16MB IC - 25R128JV
          Thank you
          • Atillaoracle
            • May 2024
            • 13
            • Ireland
            #305
            Originally posted by PycLaH
            Symptoms:
            Thanks​
            I have exactly the same issue. It was working, I read the chip and solder back now it’s not working. And the file is 16MB when I Archie it’s only 67 KB.
            can someone help?
            • PycLaH
              • Feb 2022
              • 28
              yes, very similar issue.
              • hoaca388
                Badcaps
                • Jan 2022
                • 11909
                #307
                Thank you
                File corrupted.
                • PycLaH
                  • Feb 2022
                  • 28
                  Please can you fix it ? bios 16MB file corrupted ? or smaller one ?
                  Could you send me clean files so i can restorer my laptop ?
                  please help help help
                    • 21219
                    Why is the file you posted corrupted ? .What programmer are you using,and the software version.Are you using a clip or have you desoldered the chip. Are you using the programmers Auto-detect setting,and if so does the detected chip match with the chip part number.Is the chip in the support list.
                    • PycLaH
                      • Feb 2022
                      • 28
                      NeoProgrammer, Taking Chip of the board, autodetect + Match with the chip part number,. if u look inside the file its looks corrupted. and its not me who made this decision.see previous post
                      thx. and chip is in the list too.
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11909
                        #311
                        Latitude 5430
                        Service Tag: FB1Z0T3
                        • Valentin Florin Benciu
                          • Apr 2024
                          • 8
                          • Romania
                          #312
                          Hello all,
                          Managed to take out the bios chips and extracted the bins.
                          laptop / DELL LATITUDE 5430 /
                          motherboard / DHDB42 LA-L591P /
                          cpu / INTEL i7 12TH GEN /
                          service tag / #5TN3RV3-8FC8
                          spi chip / WINBOND 32MB@WSON8
                          winbond 25R128JVSN
                          and
                          winbond 25Q256JVEN
                          I need to remove the BIOS password and the computrace.
                          Can anyone help me pls?
                          Thank you.
                          • danito
                            • Jun 2016
                            • 1007
                            • Romania
                            #313
                            Originally posted by Valentin Florin Benciu
                            Hello all,
                            winbond 25R128JVSN
                            and
                            winbond 25Q256JVEN
                            Thank you.
                            try
                              • Apr 2024
                              • 8
                              • Romania
                              #314
                              Originally posted by danito
                              try
                              this covers both problems?
                              the UC6 bios chip doesn't need anything to update it?
                              • danito
                                • Jun 2016
                                • 1007
                                • Romania
                                #315
                                Just UC2. Don't touch the other.
                                • jadao
                                  • Sep 2015
                                  • 10
                                  Hello, can someone help unlock this bios please?
                                  Service tag: 3Y6GWT3
                                  HDB42 LA-L591P Rev: 1.0 (A00) 2022-01-13
                                  Attached UC6 and UC2 dumps
                                  Thanks in advance!
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11909
                                    #317
                                    Thanks in advance!
                                    KKK
                                    • jadao
                                      • Sep 2015
                                      • 10
                                      Originally posted by hoaca388
                                      KKK
                                      Works great thank you!
                                      I have a bunch of them with same password, is there a way to retreive the password or I need to do them one by one?
                                      Thanks agin
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 11909
                                        #319
                                        Thanks agin
                                        Take them one by one
                                        • juanespty
                                          • Oct 2023
                                          • 3
                                          • Panama
                                          #320
                                          Hi. I'm having problems unlocking the BIOS/Computrace for this particular model. I've successfully been able to unlock earlier models (e.g.: 5420, 5310, etc.). I've tried with more than 1 laptop of this model, and I'm having the same problem with all of them.
                                          Information:
                                          • Model: Dell 5430
                                          • Board version: HDB42 LA-L591P Rev 1.0 (A00)
                                          • Service Tag: FVWGSQ3
                                          • UC2 and UC6 dumps attached
                                          I'm using:
                                          • T48 TL866-3G Programmer with Xgpro v12.66. I tried with 2 programmers (same model), but got the same result.
                                          • WSON 8 POGO Probe for the UC2 Winbond 25Q256JVEN chip. Using W25Q256JW@WSON8 on Xgpro.
                                          • SOIC8 Clip for the UC6 Winbond 25R128JVSN chip. Using W25Q128JV@SOIC8 on Xgpro.
                                          I'm not desoldering the chips, but reading/writing them on the board.
                                          If I try to read the chip contents with the Lithium Ion battery/charger disconnected, but the CMOS battery connected, every reading of the chips has different hash/crc values. After I disconnected the CMOS battery, the readings always matched. This doesn't happen with other models.
                                          On Xgpro If I try to read the UC2 chip contents with W25Q256FV@WSON8 or W25Q256JW@WSON8 the values returned are all 00 . With W25Q256JW@WSON8 it seems to be able to read the contents correctly.
                                          The problem is that when I try to write a bin file to the UC2 or UC6 chips, it:
                                          • "Erases" the chip in half a second. This is too fast compared to other chips. It normally takes about a minute to erase a 32MB chip.
                                          • After the content is written to the chip, it fails on the verification. The time it takes to write the bin to the chip is the usual.
                                          • If I read the chip contents after writing to it, it has a different hash value than the file that was used for programming. I haven't actually compared the content. This is happening on both the UC2 and UC6 chips. The laptop does power on afterwards, but it's still locked.
                                          Has any one been able to successfully program this model without desoldering the chip? It sounds like there's some sort of protection when the chip is on the board.
                                          Click image for larger version  Name:	UC2 Chip.png Views:	37 Size:	491.2 KB ID:	3292656
                                          UC2 Chip
                                          Click image for larger version  Name:	UC6 Chip.png Views:	37 Size:	391.2 KB ID:	3292655
                                          UC6 Chip
                                          Click image for larger version  Name:	Error programming.png Views:	32 Size:	90.2 KB ID:	3292664
                                          Error programming if "Verify after" option is selected.
                                          Click image for larger version  Name:	Ok programming without verification.png Views:	70 Size:	88.3 KB ID:	3292653
                                          No error programming if "Verify after" option is not selected, but chip content hash/CRC doesn't match with original file.
                                          Thanks!
                                          • kaput
                                            Lenovo Thinkcentre M720q, disable activated Computrace
                                            by kaput
                                            Not a BIOS request per se, but closely related. Please bear with me
                                            A while ago I found an old Lenovo Thinkcentre M720q in pieces in the electronics scrap bin at work. There was only some minor damage to the case, so collected everything and brought it home to let it dry and see if it still worked. It did
                                            Unfortunately Computrace has been activated on it. Since I'm using it as an emulation console with Lakka now, it's no big deal, but would be nice to get rid of the annoying message popping up when entering the UEFI setup, and also learn something along the way....
                                            06-28-2024, 09:36 AM
                                            HP xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation E5430 Specification for Upgrade or Repair
                                            This specification for the HP xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation boardview and xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...
                                            09-12-2024, 03:36 PM
                                            DELL Latitude 5430 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5430 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5430 boardview and 5430 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5430...
                                            09-07-2024, 06:31 AM
                                          • Syseng
                                            Lenovo P14s Gen 5 SVP unlock
                                            by Syseng
                                            This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
                                            The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
                                            06-22-2025, 07:44 AM
