Bios dump for Asus ROG Flow X13 GV301QH
  • UserGM045
    • Oct 2022
    • Russia
    Hello everyone!
    Please, help me!
    I need bios dump for BIOS ver. 402 (GV301QHAS.402 Asus EZ Flash) Asus ROG Flow X13 GV301QH.
    Tnanks!
  • Ghamidi
    • Mar 2020
    • 303
    • France
    hello
    please i need bios dump ASUS ROG Flow X13 GV301QH
    not have orginal dump
    thnx
    • Ghamidi
      • Mar 2020
      • 303
      • France
      Re: need bios dump ASUS ROG Flow X13 GV301QH
      Originally posted by Ghamidi
      hello
      thnx
      SOLVED thank you
        • 20374
        Re: Bios dump for Asus ROG Flow X13 GV301QH
        Originally posted by UserGM045
        Hello everyone!
        Please, help me!
        Tnanks!
        Post the laptop serial number,your bios backup and pictures of all barcode and QR code stickers on the motherboard.
        • cacla
          • Apr 2015
          • 442
          here
          • simplylcd
            • Nov 2015
            • 13
            Do you have a Bios dump for a GV302XIAS Asus X13 ROG Flow gaming laptop​
              • 20374
              Thats a different model. Start your own thread please, and post your backup and the laptop serial number with your request https://www.badcaps.net/forum/troubl...before-posting
              • Arshad alam4659
                • Aug 2020
                • 155
                • India
                Asus gv301qh no display need bios
                Board no = gv301qc rev 2.1
                Seriel = M5NRKD019310197
                cpu = ryzen 9 5000 series
                • peste
                  peste commented
                  Editing a comment
                  post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • Anchar777
                ASUS P1412CE need BIOS DUMP
                by Anchar777
                Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                Today, 03:39 AM
