Bios dump for Asus ROG Flow X13 GV301QH
post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread.. -
Asus gv301qh no display need bios
Board no = gv301qc rev 2.1
Seriel = M5NRKD019310197
cpu = ryzen 9 5000 series
Attached Files -
Do you have a Bios dump for a GV302XIAS Asus X13 ROG Flow gaming laptop​Leave a comment:
Re: Bios dump for Asus ROG Flow X13 GV301QH
hereAttached FilesLeave a comment:
Post the laptop serial number,your bios backup and pictures of all barcode and QR code stickers on the motherboard.Leave a comment:
hello
please i need bios dump ASUS ROG Flow X13 GV301QH
not have orginal dump
thnxLeave a comment:
Hello everyone!
Please, help me!
I need bios dump for BIOS ver. 402 (GV301QHAS.402 Asus EZ Flash) Asus ROG Flow X13 GV301QH.
Tnanks!Tags: None
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by DynaxSCHi,
Usually on ASUS boards it worked...-
by AhariHi all,
I...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by kodoxneed original bios dump, original bios has flashed by other technician before me.
attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
unit info:
Model: Asus ExpertBook B1400CBA-0711A1235U
S/N: R6NXNZ006657238
CN: 7F6F
Mainboard Code: B1500CBA R2.1...-
- Loading...
