Clevo NH70RD MB:6-77-NH70RDQ0-D02A-1E bios
  • Ferimonka
    • Nov 2019
    • 40
    • United Kingdom
    Hi. I need a new bios file, please.
    Clevo NH70RD
    Attaching old faulty bios (No display)
    • 22279
    Re: Clevo NH70RD MB:6-77-NH70RDQ0-D02A-1E bios
    Clevo NH70RD
    https://repo.palkeo.com/clevo-mirror...Cx_RAx_RHx(Q)/
    Log in using
    Username: repo
    Pass: repo
    • Ferimonka
      • Nov 2019
      • 40
      • United Kingdom
      Thank you for the hidden repository. I think I found the right one but not sure how to flash it to a chip. When I unzipped the file there is lot of exe files. Did someone done it before to point me how-to? Thank you.
        • 22279
        did you get the RDQ one.What are the file names you got
        • Ferimonka
          • Nov 2019
          • 40
          • United Kingdom
          I downloaded NHxxRC_RDx_B10706.zip as I assuming its for my laptop.
          It's a zip so please have a look what's inside (attached) and let me know how to deal with it. Thank you in advance.
            • 22279
            Download and extract this one
            Bios https://repo.palkeo.com/clevo-mirror...RDx_B10716.zip
            The bios is named NHx0RC.16
            The EC is this one i think,i couldnt see a newer one
            EC https://repo.palkeo.com/clevo-mirror...Dx_EC10703.zip
            • Ferimonka
              • Nov 2019
              • 40
              • United Kingdom
              Thank you. The 26.6MB zip I downloaded from your link also contains no bin file I would be able to use. It has got lot of files. Can you find out where to get the bin file for me please?
                • 22279
                The bios is named NHx0RC.16 ,if your programmer won`t recognise it because of the .16 file extension just rename it to .bin , NHx0RC.16 rename to NHx0RC.bin
                • Ferimonka
                  • Nov 2019
                  • 40
                  • United Kingdom
                  Ah, I missed a line while reading. I tried flash the bios but still the same. Laptop is power cycling and not booting, no screen. I didn't flash EC cause never done it. Can this be an issue?
                    • 22279
                    Forget the EC for now,it would need programming with a dedicated IO programmer through the keyboard connector.Its probably got some other hardware issue.If you want some help with it and youve got a multimeter and a bit of patience you can start a new thread in the laptop forum https://www.badcaps.net/forum/forumdisplay.php?f=23 .The service manual/schematic is this one https://repo.palkeo.com/clevo-mirror...NH58RCQ_SM.zip ,you can post it as an attachment to your new thread or post it seperately in the Schematic requests section as a new thread and link to it from your repair thread
                    • to5it0
                      Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                      by to5it0
                      Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                      I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                      This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                      I have opened the laptop and identified the main BIOS chip...
                      10-24-2025, 01:35 AM
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      08-05-2025, 05:12 AM
                    • maanee11
                      Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                      by maanee11
                      Hello Everyone,
                      I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                      It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                      In the website, you can only see specs etc.
                      I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                      11-08-2025, 04:08 AM
                    • m1ch43lzm
                      Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                      by m1ch43lzm
                      Hi everyone
                      I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                      Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                      Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                      There's also an extra OTP Secu.R...
                      09-06-2025, 05:47 PM
                    • princebuzz
                      BIOS REQUEST FOR CLEVO PE60RNE-G
                      by princebuzz
                      I’m looking for the correct BIOS / EC / ME firmware for a CLEVO PE60RNEQ laptop that was sold by Scan as a 3XS system. The laptop has developed a boot issue that appears to be firmware-related, and I’m hoping someone can provide a dump or the correct files.
                      System Information:
                      • Base laptop model: CLEVO PE60RNEQ (NP60RNEQ)
                      • Motherboard ID: PE60RNE_RND_RNC
                      • Vendor: Scan 3XS (UK)
                      • Unfortunately, I no longer have the original box.
                      Firmware Versions (from BIOS):
                      • BIOS Version: 1.07.07SCI
                      • EC/KBC Firmware Version: 1.07.07
                      • Intel ME Firmware Version:
                      11-29-2025, 03:09 PM
