i have asus motherboard TP420IA having bios password.the ic is not detecting in my programmer rt809f.anyone have backup bios of this board please provide it.or help me how can i let the programmer detect the bios chip the chip is 1.8v xmc 25QU128BHIQ.
asus tp420ia
Re: asus tp420ia
Here is full biosAttached Filesif you find these attachements useful please consider making a small donation to the site
no boot ssd. Help ..!!!Attached Filesif you find these attachements useful please consider making a small donation to the site
Read the rules before posting
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by STKR123Greetings badcaps community,
I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
I learned that desoldering...10-29-2024, 06:03 AM -
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
- I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
- I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
- I could only locate two chips that look like bios chips. Could someone verify this
- Loading...
