Lenovo ThinkBook 14 G2 ITL FLV34 LA-K051P bios
  • jj.ww
    replied
    hello. volinakis.
    it worked thank you.
    i need to do 3 more of these laptop. could i use the 16MB file and use golden key to just change the dmi stuff ?
    or do i just need to post the 16mb files and system info ?
    thanks again​
  • volinakis
    replied
    Originally posted by jj.ww
    hello is it possible for somebody to help unlock bios password.
    MODEL NAME :THINKBOOK 14 G2 ITL
    FLV34 LA-K051P REV:1B
    S/N MP1Y9VDW
    MTM:20VD008UUK
    try. Write only 16Mb chipset.
  • jj.ww
    replied
    S/N MP1Y9VDW
    MTM:20VD008UUK
  • elariz
    replied
    its clean me region
    working 100%
  • peste
    replied
    Originally posted by -danger-
    Hello. can I post bios dump for password reset? ThinkBook 14 G2 ITL
    I can donate if needed )
    post S/N, full name and model, motherboard model,post the original contents of the bios chip..etc.
  • -danger-
    replied
    ​I can donate if needed )
  • Pavel Kudryavtcev
    replied
    Originally posted by volinakis
    check soldering
    There really was a problem with soldering. I redid it, checked it with a microscope. The behavior when starting the laptop has changed as it was after the f8cn58ww update. The power button, esc and caps lights up, then everything goes out and lights up again, while caps goes out and nothing else happens. If there are any other options on how to fix this, please suggest.
    P.S. Please note that I previously updated Intel Management Engine 15.0 Firmware to version F8ME05WW.
    Thank you!​
  • volinakis
    replied
    Originally posted by Pavel Kudryavtcev
    Unfortunately, it didn't work. But the symptoms are different, earlier the LEDs on the caps lock and escape were lit, now only the power button slowly blinks. As if there is no BIOS at all.
    check soldering
  • Pavel Kudryavtcev
    replied
    Try
  • volinakis
    replied
    Hi
    Lenovo Thinkbook 14 G2 ITL
    MO: MPNXB13230E6
    MTM: 20VD00CSUA
    Factory ID: PRC4
    S/N: MP1ZHRPF
    After updating to firmware f8cn59ww, the fan stopped working and the sound card was not detected. On the support forum, the manufacturer sent me the previous firmware f8cn58ww and after this update, the screen stopped showing. HDMI connection does not work. I only have dumps of the firmware f8cn58ww, I will attach them to the message. I will also add the installation file.
    I also tried the firmware from post 19, it does not work.
    Please help me fix the firmware.
    Thank you!​
    Try
  • Pavel Kudryavtcev
    replied
    Hi
    MO: MPNXB13230E6
    MTM: 20VD00CSUA
    Factory ID: PRC4
    S/N: MP1ZHRPF
    Thank you!​
  • volinakis
    replied
    Originally posted by shhibycba
    Hello Shiyab, I have loaded the Dump bios in the attached file, is that not what you need? Excuse my question but I am new to this, if you tell me I will send everything you need, thank you for your help with this
    that's NOT bios chipset, read chipsets marked in yellow
  • shhibycba
    replied
  • shiyab
    replied
    Hello everyone, I would like to request help to unlock the bios that I have, I don't know if the bios that you already posted work for me too. I attach my locked bios, I hope you can help me, thanks in advance (serial MP22PS7T)​
    post backup file
  • shhibycba
    replied
  • qayyum786
    replied
    Originally posted by abdulhashim
    Hello, can you please fix this file
    problem no display
    SN:MP2C2V6D
    Try
  • abdulhashim
    replied
    problem no display
    SN:MP2C2V6D
  • AlecClaire
    replied
    Originally posted by hoaca388
    ThinkBook 14 G2 ITL Laptop - Type 20VD
    Thank you but I had no luck.
    Just by flashing 8MB and 16MB .bin's after hitting the power button it lights up for about four seconds than the light turns off and lights up again and so on - but the laptop doesn't start and does not take power (meter shows 1-2W only). Before, meaning on the original corrupted BIOS after hitting the power button the laptop turned on and the power button stayed lighten up stayed that way as the computer was still on.
    Question for me is because I've never done this before - do I have to flash the attached EC.bin? I've also attached photos of the MB - maybe I'm doing something wrong here.
    Any ideas what to try next?
  • hoaca388
    replied
    Originally posted by AlecClaire
    Gondor calls for aid - during BIOS update it got corrupted despite everything being done by the book. This is my own laptop.
    ThinkBook 14 G2 ITL
    MB: FLV34 LA-K051P Rev : 1B
    S/N: MP1XK11C
  • AlecClaire
    replied
    ThinkBook 14 G2 ITL
    S/N: MP1XK11C
  • Wahaz
    by Wahaz
    10-30-2023, 08:42 PM
  • lucaszmn
    by lucaszmn
    Problem:
    Initial Findings:
    • I concluded that the
    08-12-2025, 03:01 PM
  • TecnicaNTT
    Lenovo Thinkbook 16P G2 ACH - BIOS Serial number missing
    by TecnicaNTT
    I got a Lenovo Thinkbook 16P G2 ACH on the bench with a botched BIOS (somehow my client blanked it). I restored the laptop and got it up and running with original BIOS from Lenovo Support website.
    My problem is now that the machine details are missing in the BIOS (Serial Number, MTM, etc.)
    I tried to write the details with the Lenovo Uone Tool but had now luck. It is giving me an error: "ERROR: Locate protocol with LenovoEeprom, Status=[e]. EEPROM fail when reading or writing data."
    I am now asking here for help if anyone knows how to do this in...
    09-20-2024, 08:10 AM
  • grimacelord
    Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
    by grimacelord
    Hello there.
    I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
    History:
    1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
    I searched for this error online and discovered...
    03-15-2023, 03:29 PM
    Lenovo ThinkBook ThinkBook 14s Yoga ITL Notebook Specification for Upgrade or Repair
    This specification for the Lenovo ThinkBook ThinkBook 14s Yoga ITL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkBook 14s Yoga ITL boardview and ThinkBook 14s Yoga ITL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-07-2024, 04:10 AM
