asus pro p3540fa bios dump
  • reset1986
    • 308
    • italia
    hi to all I have this pc with main model p3540fb rev 2.0 that no led lights up and no fan rotation,
    there are no short circuits and I receive voltages of 19v 5v 3v,
    on the bios of the chip I get tensions but nothing happens and nothing heats up,
    I was thinking about a BIOS corruption, I am attaching the backup and the BIOS downloaded from the original site,
    i need someone to repair my backup, thanks
  • hoaca388
    Badcaps
    • Jan 2022
    • 11659
    Re: asus pro p3540fa bios dump
    Here
    • reset1986
      • 308
      • italia
      Originally posted by hoaca388
      Here
      Thanks you, working
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • Anchar777
        ASUS P1412CE need BIOS DUMP
        by Anchar777
        Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
        06-26-2025, 03:39 AM
      • kcp0085
        Request BIOS dump for ASUS FA617NS-A16.R77600
        by kcp0085
        Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
        I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
        Specs:
        - ASUS TUF FA617NS-A16
        - CPU: AMD Ryzen 7
        - BIOS chip: Winbond W25Q16JVSIQ (2MB)
        If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
        Thanks in advance!​
        05-02-2025, 12:52 AM
