Request BIOS dump for ASUS FA617NS-A16.R77600
  • kcp0085
    • May 2025
    Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
    I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
    Specs:
    - ASUS TUF FA617NS-A16
    - CPU: AMD Ryzen 7
    - BIOS chip: Winbond W25Q16JVSIQ (2MB)
    If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
    Thanks in advance!​
  • danito
    • Jun 2016
    • 899
    • Romania
    Specs:
    - CPU: AMD Ryzen 7
    Thanks in advance!​
    post the original bios of the laptop even if it is corrupted,the motherboard model, etc.
    • DozNaka
      • Jul 2025
      • Trinidad & Tobago
      I have the 7700S variant of this laptop (FA617NT)
      That chip you just stated only contains the VBIOS for the 7600S which you can obtain from the techpowerup website (backup first before flashing)
      The actual bios chip is circled in red and may require a different connector for your programmer
      I cannot provide the BIOS file for this laptop as I have a different model
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • Anchar777
        ASUS P1412CE need BIOS DUMP
        by Anchar777
        Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
        06-26-2025, 03:39 AM
