asus pro p3540fa bios dump
  • reset1986
    • Dec 2014
    • 308
    • italia
    hi to all I have this pc with main model p3540fb rev 2.0 that no led lights up and no fan rotation,
    there are no short circuits and I receive voltages of 19v 5v 3v,
    on the bios of the chip I get tensions but nothing happens and nothing heats up,
    I was thinking about a BIOS corruption, I am attaching the backup and the BIOS downloaded from the original site,
    i need someone to repair my backup, thanks
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    Re: asus pro p3540fa bios dump
    Here
    • reset1986
      • Dec 2014
      • 308
      • italia
      Originally posted by hoaca388
      Here
      Thanks you, working
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • ArkzG
        [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
        by ArkzG
        Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
        What I currently have available:
        - Model: FA506NF (2021)
        - BIOS chip: GD25LQ16 (16Mbit/2MB)
        - Tools: CH341A programmer ready to use
        Does anyone have either a clean 2MB .bin dump of this model,...
        09-26-2025, 09:34 PM
      • kodox
        Asus ExpertBook B1400CB Bios Dump Needed
        by kodox
        need original bios dump, original bios has flashed by other technician before me.
        attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
        unit info:
        Model: Asus ExpertBook B1400CBA-0711A1235U
        S/N: R6NXNZ006657238
        CN: 7F6F
        Mainboard Code: B1500CBA R2.1...
        08-16-2025, 12:20 PM
