Surface Pro 6 Bios (Clean Region ME + OFF motherboard)
  • Penetre
    • Apr 2022
    • 7
    • España
    Hello everyone, I write in case you can help me with my little Surface. I am a person who wants to try to fix something and usually gets into more trouble.
    I have been trying to get the materials for 8 months to be able to desolder and flash the bios. After getting the programmer and the hot air station, I killed the surface.
    I have managed to extract the Bios from the chip and modify with HxD the region Me, to leave it clean, using the files of the same version.
    I attach the Original files and with R.Me clean, in case someone could check, if they are correct.
    The surface does not turn on, no logo, no light on the power cord, nothing.
    I think there may be some broken component, when removing the bios.
    someone could help me??
    Thank you very much to all, and forgive, so much text.
    Version in my language, I use google translate for English... Sorry.....
    Hola a todos, os escribo por si podeis ayudarme con mi pequeña Surface. Soy una persona que quiere intentar arreglar algo y suele meterse en mas problemas.
    Llevo 8 meses intentando conseguir los materiales para poder desoldar y flashear la bios. Despues de conseguir el programador y la estacion de aire caliente, he matado a la surface.
    He conseguido extraer la Bios del chip y modificar con HxD la region Me, para dejarla limpia, usando los archivos de la misma version.
    Os adjunto los archivos Originales y con R.Me limpia, por si alguien pudiera revisar, si estan correctos.
    La surface no enciende, no logo, no luz en el cable de alimentacion, nada.
    Yo creo que puede haber algun componente roto, al retirar la bios.
    Muchisimas gracias a todos, y perdonad, tanto texto.
    • 20361
    Re: Surface Pro 6 Bios (Clean Region ME + OFF motherboard)
    Post the original unmodified bios, the one before you made all the changes.
    • Penetre
      • Apr 2022
      • 7
      • España
      I'm back to putting the original bios.. but the problem continues.. that's why I think q is some physical damage
        • 20361
        Did you have a light on the adapter before you messed with the bios.If you didn`t its more likely to be a power issue
        • Penetre
          • Apr 2022
          • 7
          • España
          the surface worked before I started to disassemble everything. now the charging light no longer comes on.
          you know how to tell me where to start looking for the breakdown?
          1000thx
          I think there was a spark when removing the flex from the lcd, but I don't see anything burned
          • muhuruu
            Surface pro 4 bios request
            by muhuruu
            Hey. Sometime ago i bought broken surface pro 4 supposedly it was dead. But turns out it was just a faulty charger. Although when it powered on and after all updates, touchscreen didn't work it also doesn't work in UEFI. On my original bios in device menager it shows yellow triangles on Surface ME and Surface Touch, hid-compliant touchscreen was missing. I already replaced touchscreen and touchscreen board, i've broken the orginal screen when trying to open surface. I already tried diffrent bios files from internet. With the latest one i was able to install the drivers for Surface ME and Surface...
            01-22-2024, 05:38 AM
          • Vesko356
            by Vesko356
            08-11-2023, 03:27 AM
            Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) 3 Specification for Upgrade or Repair
            This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock 2 boardview and Surface Book 3 + Surface Dock 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
            09-06-2024, 08:10 PM
