ASUS ROG G750JX board code G750JW rev 2.1 BIOS Needed
  • rediii
    h???, spurrrn
    • Mar 2018
    • 485
    • somewhere in europe
    hello guys, i need a bios dump for this model. thank you!
    already got it! SORRY
  • tujuhkalitujuh
    • Oct 2013
    • 26
    • Indonesia
    Hello brothers and masters, as the title mentioned ASUS ROG G750JX board code G750JW rev 2.1 BIOS.
    any help will be appreciated. Thanks in advance.
    • peste
      • Dec 2016
      • 12254
      • ROMANIA
      Re: ASUS ROG G750JX board code G750JW rev 2.1 BIOS Needed
      read this..
      post the original bios of the laptop even if it is corrupted..
      • tujuhkalitujuh
        • Oct 2013
        • 26
        • Indonesia
        Originally posted by peste
        read this..
        it is not corrupted, the bios chip is damaged and even can't read it.
        I already try Asus G750JH bios and the laptop can turned on, but the new problem is the Nvidia GTX770M can't work and not recognized by any driver available.
        And I can't reflash using Original Asus Web G750JX. it says the version is not supported with this type of BIOS.
        So should I use this unfitted G750JH bios for requesting G750JX for mine?
        • peste
          • Dec 2016
          • 12254
          • ROMANIA
          you should have said that the bios chip cannot be read..ok..post pictures with the stickers from the ram memory area...or a white square with a QR code..
          • tujuhkalitujuh
            • Oct 2013
            • 26
            • Indonesia
            Really appreciate for you @peste.
            Here is the picture of my laptop
            • peste
              • Dec 2016
              • 12254
              • ROMANIA
              really appreciate for you @peste.
              try..
              • tujuhkalitujuh
                • Oct 2013
                • 26
                • Indonesia
                try..
                Already tested it and it works flawlessly. Thank you master
                • doktorkomputer
                  • Aug 2016
                  • 63
                  • Poland
                  THX
                  • Domino124
                    • Feb 2025
                    • 4
                    • United States of America
                    try..
                    Although this is quite old but I have this as a spare laptop 750jx too and it was working fine until a recent windows update got the bios to quit. Blank screen with just power lights on. I was wondering how did you updated the bios with blank screen? My usb drive on there is not working only DVD writer comes in and out when power is on. Anyone help ? I use this as a trading machine.
                    • peste
                      • Dec 2016
                      • 12254
                      • ROMANIA
                      you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                      • Domino124
                        • Feb 2025
                        • 4
                        Thanks I found one link that doesn't require desoldering bios chips. https://youtu.be/2Y06x1f22B0?si=zrfwVg8__mZR96Zj.
                        • peste
                          • Dec 2016
                          • 12254
                          • ROMANIA
                          why are you asking for help and then doing something else..don't use the clip because you will have errors..if you don't have anything to unsolder, solder wires between the chip and the programmer..
                          • Domino124
                            • Feb 2025
                            • 4
                            Thanks mate I am looking for answers. You guys are gurus and I am a newbie in this type of maintenance. Thanks for your gracious help and understanding.
                            • Domino124
                              • Feb 2025
                              • 4
                              Hi mate, there is no one in my area willing to do this type of work for bios programming for an old laptop. I tried to see if usb port is working by putting a USB stick with flashing lights and it does light up. I don't know if I could use this as a good sign or not. If anyone willing to have alternate views other than doing reprogram of the chip ( as I am not a tech like you all to do by myself).
                              • peste
                                • Dec 2016
                                • 12254
                                • ROMANIA
                                it doesn't work on USB..you need a programmer..
                                • throwaway327
                                  by throwaway327
                                  Model No: RC72LA
                                  Serial No: SBNVKD001014459
                                  06-18-2025, 05:52 PM
                                • jbonavita
                                  by jbonavita
                                  Some issues
                                  Things I tried
                                  04-29-2025, 09:38 PM
                                • exerion5000
                                  Bios Needed For Asus X515EA Pcb X415EA R2.0
                                  by exerion5000
                                  Asus X515EA_No Power_GD25B127D@SOIC8.rar
                                  Hi Everyone! , i need repair the original bios corruptes of this model machine (Bios Needed For Asus X515EA Pcb X415EA R2.0) , the unit no power on , i test several bios for this model with some issues maybe related to especific version (keyboard partially work or no work , SSD no detected ,Etc ) so y let more data below if help , many thanks in advance!...
                                  02-17-2025, 01:34 PM
                                • Newmultifail
                                  Asus g750jx Bios turns off after 30 minutes
                                  by Newmultifail
                                  I have a problem with the asus g750jx, it shuts down exactly every 30 minutes. There is no overheating and the like, it works perfectly for half an hour. it turns off both in bios and in windows. My guess is that the bios is the problem, would anyone like to take a look and try to fix this bios so I can flash it again?
                                  I should mention that the bios update did not help.
                                  backup i sn...
                                  I have a problem with the asus g750jx, it shuts down exactly every 30 minutes. There is no overheating and the like, it works perfectly for half an hour. it turns off both in bios and in windows. My guess is that the bios is the problem, would anyone like to take a look and try to fix this bios so I can flash it again? I
                                  12-19-2024, 03:41 PM
                                • lrouw84
                                  by lrouw84
                                  Hi there,
                                  01-28-2023, 01:31 PM
