ASUS ROG G750JX board code G750JW rev 2.1 BIOS Needed
    hello guys, i need a bios dump for this model. thank you!
    already got it! SORRY
    Hello brothers and masters, as the title mentioned ASUS ROG G750JX board code G750JW rev 2.1 BIOS.
    any help will be appreciated. Thanks in advance.
      Re: ASUS ROG G750JX board code G750JW rev 2.1 BIOS Needed
      read this..
      post the original bios of the laptop even if it is corrupted..
        Originally posted by peste View Post
        read this..
        it is not corrupted, the bios chip is damaged and even can't read it.
        I already try Asus G750JH bios and the laptop can turned on, but the new problem is the Nvidia GTX770M can't work and not recognized by any driver available.
        And I can't reflash using Original Asus Web G750JX. it says the version is not supported with this type of BIOS.
        So should I use this unfitted G750JH bios for requesting G750JX for mine?
          you should have said that the bios chip cannot be read..ok..post pictures with the stickers from the ram memory area...or a white square with a QR code..
            Really appreciate for you @peste.
            Here is the picture of my laptop
              really appreciate for you @peste.
              try..
                try..
                Already tested it and it works flawlessly. Thank you master
                  THX
                    try..
                    Although this is quite old but I have this as a spare laptop 750jx too and it was working fine until a recent windows update got the bios to quit. Blank screen with just power lights on. I was wondering how did you updated the bios with blank screen? My usb drive on there is not working only DVD writer comes in and out when power is on. Anyone help ? I use this as a trading machine.
                      you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                        Thanks I found one link that doesn't require desoldering bios chips. https://youtu.be/2Y06x1f22B0?si=zrfwVg8__mZR96Zj.
                          why are you asking for help and then doing something else..don't use the clip because you will have errors..if you don't have anything to unsolder, solder wires between the chip and the programmer..
                            Thanks mate I am looking for answers. You guys are gurus and I am a newbie in this type of maintenance. Thanks for your gracious help and understanding.
                              Hi mate, there is no one in my area willing to do this type of work for bios programming for an old laptop. I tried to see if usb port is working by putting a USB stick with flashing lights and it does light up. I don't know if I could use this as a good sign or not. If anyone willing to have alternate views other than doing reprogram of the chip ( as I am not a tech like you all to do by myself).
                                it doesn't work on USB..you need a programmer..
