i need bios for DELL Latitude 3189
  • dqtech
    Badcaps
    • Jul 2018
    • 638
    • N/A
    Re: i need bios for DELL Latitude 3189
    thanks
    • Muhammad Mubeen
      • Jun 2023
      • 8
      • Pakistan
      i have 3189 every time start laptop time date error plz fix my bios
      servive tag=9G9LNN2
      • m.hamzashafiq7810
        WORKSTATION
        • Nov 2021
        • Pakistan
        CAV00/CAV10 LA-E371P REV 2.0 SR2Z5 PENTIUM N4200
        TPM DEVICE IS NOT DETECTED & WINDOWS NOT BOOTING UP
        LAPTOP TURN OFF AFTER THIS MESSAGE
        IN BIOS TPM OPTION ALSO NOT AVAILABLE
        PLZ SOLVE IT PLZ PLZ
      • m.hamzashafiq7810
        WORKSTATION
        • Nov 2021
        • Pakistan
        I am sorry
        Service tag 2TG98H2
        • munir100
          • Dec 2018
          • 187
          • uae
          I have dell 3189 tpm error can any one fixs thanks st GYXZNQ2 Hera is bios file LA-E371P REV 3.0 (A02)
          • piszpunta
            • Jan 2019
            • 253
            • poland
            #26
            try
            • munir100
              • Dec 2018
              • 187
              • uae
              #27
              Originally posted by piszpunta
              try
              THANKS for reply not work
              • Blaze Tech
                Learner
                • 214
                • Ghana
                #28
                TRY
                • munir100
                  • Dec 2018
                  • 187
                  • uae
                  #29
                  Originally posted by Blaze Tech
                  TRY
                  thanks for reply but still tpm error
                  • pepa13
                    • Jul 2021
                    • 5
                    • Ukraine
                    #30
                    Hello. I need your help. Laptop DELL Latitude 3189, MB CAV00/CAV10 LA-E371P Rev:3.0(A02)
                    Express Service Code - 16489968798, Service Tag on the 7KPP1N2 case, there was a different Service Tag in the firmware, the BIOS chip is soldered, that is, the BIOS inside the SPI Flash is not native.
                    On loading it says - "Alert! TPM could not be initialized"
                    It was sold to me as a working one. I tried all the simple steps. Pulling out the cord, downgrading and upgrading the BIOS version, replacing the battery... I flashed the BIOS from this topic - Lat_3180_3189_1.17.0 TXE_CLEAN.BIN No changes.
                    You need a dump BIOS, which may be suitable in this case, or some useful advice.​
                    • danito
                      • Jun 2016
                      • 1068
                      • Romania
                      #31
                      put bios recovery here
                      • pepa13
                        • Jul 2021
                        • 5
                        • Ukraine
                        #32
                        I received the laptop with a non-native BIOS and without an SSD, so I don't have bios recovery. Inside the SPI Flash the firmware is now Lat_3180_3189_1.17.0 TXE_CLEAN.BIN
                        There is a backup of the firmware that was there before.​
                        • pepa13
                          • Jul 2021
                          • 5
                          • Ukraine
                          #33
                          Sorry, I didn’t immediately understand what needed to be done. Lack of knowledge + lack of knowledge of the language, I thought that I needed a backup of the factory BIOS. Here is the BIOS Recovery file copied from the EFI partition. Service Tag 7KPP1N2 - factory, from the laptop cover, registered the first time it was turned on after the firmware.
                          • munir100
                            • Dec 2018
                            • 187
                            • uae
                            #34
                            DELL Latiude 3189 r ST- GYXZNQ CAV00/CAV10 LA-E371P REV 3 (A02) Problem is no dispaly here is bios file can any fix thanks
                            • SAF1
                              • Sep 2022
                              • 6
                              • Ghana
                              #35
                              My DELL Latitude 3189 only boot to bios and not windows despite seeing the SSD.
                              It gives me an alert (TPM device is not detected), i enable secure boot but same problem.
                              i needs help
                              • Ali_Khan
                                • Dec 2023
                                • 13
                                • Egypt
                                #36
                                i needs help
                                For booting issue check boot options in bios settings, for tpm alert either upgrade the bios version or downgrade it, if still same issue then dump your bios and upload file here for repair
                                • pepa13
                                  • Jul 2021
                                  • 5
                                  • Ukraine
                                  #37
                                  i needs help
                                  I have a similar problem. TPM error. BIOS reflashing did not help, tried several options. Try to enter Windows through the boot menu, pressing F12 during boot and selecting the Windows Boot Manager item. My laptop boots into Windows this way, it works fine, but until the first reboot, then you need to enter the F12 boot menu again.
                                  • BlessedMiracle
                                    • Sep 2022
                                    • 5
                                    • Nigeria
                                    #38
                                    Hello please fix this bios. it do power on fully, bliking amber lights and white
                                    TAG: S/N 387F3H2
                                    here's the dump bin attached
                                    • Ocajunior
                                      • Nov 2022
                                      • Tanzania
                                      #39
                                      try this one.
                                      It says the data size is larger than chip size. Help please...
                                        • 21666
                                        I suspect you are trying to flash to the wrong chip. What part number is etched on top. You should always make a backup before trying to flash any other bios.
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
                                        • jhanra
                                          by jhanra
                                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                          11-02-2024, 04:19 AM
                                          DELL Latitude 3189 Hybrid (2-in-1) 3000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 3189 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3189 boardview and 3189 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                                          09-06-2024, 05:40 AM
                                        • YOUCEF4787
                                          Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
                                          by YOUCEF4787
                                          I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
                                          Initial Problem:
                                          The laptop was completely dead, no signs of life, no power LED.
                                          Action Taken:
                                          I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
                                          Current Situation & The Main Issue:
                                          The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
                                          09-21-2025, 12:19 PM
